365-664_ALT_0
365-664_ALT_1
365-664_ALT_2
365-664_ALT_3
M.POWER FLTS Flat Lying Trammel Head Set
Brand:| Model: A-USA/MP/FLTS
Product Video
Draw circles right, the first time, using M.POWER's FLTS flat lying trammel head set. The FLTS attaches to an aluminum ruler or length of steel to create nearly any size trammel. Use the included blade to cut perfect circles in veneer, or attach to a square for perfect parallel lines!
  • Attach to an aluminum rule or length of steel to mark circles of any size
  • Use the included blade to cut perfect veneer circles
  • Low center-of-gravity design for flat positioning and hands-free stability
  • Die-cast electroplated trammel heads with a carbon steel pivot point
365-664
Weight: 0.5 lbs.
IN STOCK
List Price$22.99
You Save13%
$19.98
Part # 365-664
Need to draw a circle? Or rather… Need to draw an accurate circle? One where the finishing point actually meets the starting point? M.POWER's FLTS flat lying trammel head set will guarantee you exactly that. Simply clip the two trammel scribe heads onto any length of steel or aluminum rule from six inches to six feet in length, measure out the required radius between the scribe point and pencil point and lock the second scribe unit. Choose either the included pencil or the hyper fine cutting blade and strike that arc. Attach to a square for perfect parallel lines on almost any surface.
The flat lying, low center-of-gravity design increases accuracy and offers hands-free stability. Versatility is built into the FLTS; you can also use it as a deep range marking gauge or a mortise gauge. For precision marking where a pencil line just isn't fine enough, the FLTS includes a blade post and a bar of replaceable blades allowing you to strike a hyper fine line. Set it up as a trammel compass and accurate circles can be cut out in veneer, light card and paper. Made in England. Two-year warranty.
Includes:
• 6 replaceable blade segments
• 2 die-cast, electroplated trammel heads
• 1 carbon steel pivot point
• 1 angled steel blade post
• 1 Allen key
• 1 pencil
  • BrandM.POWER Tools
  • ModelA-USA/MP/FLTS
  • Part Number365-664
  • UPC815521000015
  • Product CategoryMiscellaneous Tools
    (1 Reviews)
  • Weight0.5 lbs.
View similar products to the M.POWER FLTS Flat Lying Trammel Head Set
in the Miscellaneous Tools product category.
M.POWER FLTS Flat Lying Trammel Head Set is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Works as advertisedA simple tool for scribing circles and arcs of any diameter,just add the appropriate length straightedge.Trammels are far easier to use in the shop than a compass, and this one is very well made.
Date published: 2013-07-04
What is the smallest radius that can be drawen with this device ( I need 17/32 inch)?
Asked by: Wes77
This is infinitely adjustable from 0 to however wide the ruler is they are attached to. A 17/32" circle is perfectly possible.
Date published: 2014-12-02
Where can I get replacement blades fro the flat lying trammel
Asked by: RAy1
You will have to contact M.POWER directly for replacement blades, we do not offer them at this time.
Videos
Customer projects that include: M.POWER FLTS Flat Lying Trammel Head Set
Related Products
M.POWER C3D 3D Try Square
Part # 365-658
