Morel DMS 37 1-1/8" Shielded Soft Dome Tweeter
Brand:|Part # 277-047
The DMS 37 features a hand treated 1-1/8" soft dome, horn loading for higher efficiency, and high dynamic range without compression of SPL. The magnet assembly is vented into a damped rear chamber to lower resonance and to eliminate "honking" at lower frequencies.
Part # 277-047
The DMS 37 features a hand treated 1-1/8" soft dome, horn loading for higher efficiency, and high dynamic range without SPL compression. The magnet assembly is vented into a damped rear chamber to lower resonance and to eliminate "honking" at lower frequencies. Ferro fluid cooling provides reduced distortion and higher power handling.
Specifications: • Power handling: 200 watts RMS/280 watts max • Voice coil diameter: 1-1/8" • Impedance: 8 ohms • DC resistance: 5.2 ohms • Frequency response: 1,800-22,000 Hz • Fs: 700 Hz • SPL: 93 dB 1W/1m • Net weight: 1-1/4 lbs. • Dimensions: Overall Diameter: 3-11/16", Cutout Diameter: 2-13/16", Mounting Depth: 2-1/4", Magnet Diameter: 2-13/16", Magnet Height: 2-1/8".
  • BrandMorel
  • Part Number277-047
  • UPC844632019913
  • Product CategoryTweeters
  • Weight1.914 lbs.
View similar products to the Morel DMS 37 1-1/8" Shielded Soft Dome Tweeter
in the Tweeters product category.
