Morel CAW 938 9" Cast Frame Woofer
Brand:|Model: CAW 938|Part # 297-086
The Classic Advanced line of woofers is based on Morel's classic line - the renowned MW series. This woofer features an aerodynamic Uniflow™ open chassis, large diameter spider, reinforced ferrite magnets resulting in higher power handling, and low resonance frequency and Qts points.
OUT OF STOCK
Awaiting Updated Due Date
List Price$192.99
You Save21%
$152.00
Part # 297-086
  • Uniflow™ aluminum diecast chassis
  • Large 3" Hexatech™ aluminum voice coil
  • Shallow profile DPC cone
  • High flux ferrite double magnet system
  • High power handling
The Classic Advanced line of woofers is based on Morel's classic line - the renowned MW series. These products have high power handling due to the aerodynamic Uniflow™ open chassis and large diameter spiders. This woofer has reinforced ferrite magnets for the double magnet system delivering higher magnetic flux motor, resulting in a low resonance frequency and Qts points. Latest version of Morel's MW-265 and MW-266 woofers.
  • Nominal Diameter9"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response20 to 3,000 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)29 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.62 mH
  • Mechanical Q (Qms)2.32
  • Electromagnetic Q (Qes)0.67
  • Total Q (Qts)0.52
  • Compliance Equivalent Volume (Vas)2.47 ft.³
  • Mechanical Compliance of Suspension (Cms)1.07 mm/N
  • BL Product (BL)6.88 Tm
  • Diaphragm Mass Inc. Airload (Mms)27.5g
  • Maximum Linear Excursion (Xmax)4.25 mm
  • Surface Area of Cone (Sd)219 cm²
  • Cone MaterialPoly Composite
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.74"
  • Baffle Cutout Diameter7.8"
  • Depth3"
  • # Mounting Holes8
  • Sealed Volume1.72 ft.³
  • Sealed F344 Hz
  • Vented Volume4.28 ft.³
  • Vented F321 Hz
  • BrandMorel
  • ModelCAW 938
  • Part Number297-086
  • UPC844632066023
  • Product CategoryWoofers
    (4 Reviews)
  • Weight4 lbs.
View similar products to the Morel CAW 938 9" Cast Frame Woofer
