Morel CAW 638 6" Cast Frame Woofer
Brand:|Model: CAW 638|Part # 297-084
The Classic Advanced line of woofers is based on Morel’s classic line - the renowned MW series. This woofer features an aerodynamic Uniflow™ open chassis, large diameter spider, reinforced ferrite magnets resulting in higher power handling, and low resonance frequency and Qts points.
- Order Soon - Only 3 Left In StockMore Due In September 22, 2016
List Price$173.99
You Save22%
$136.00
Part # 297-084
  • Uniflow™ aluminum diecast chassis
  • Large 3" Hexatech™ aluminum voice coil
  • High flux ferrite double magnet system
  • Shallow profile DPC cone
  • High power handling
The Classic Advanced line of woofers is based on Morel’s classic line - the renowned MW series. These products have high power handling due to the aerodynamic Uniflow™ open chassis and large diameter spiders. This woofer has reinforced ferrite magnets for the double magnet system delivering higher magnetic flux motor, resulting in a low resonance frequency and Qts points. Latest evolution of Morel's MW-164, MW-166, and MW-168 woofers.
  • Nominal Diameter6"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response30 to 5,000 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)43 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.63 mH
  • Mechanical Q (Qms)2.2
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.46
  • Compliance Equivalent Volume (Vas)0.55 ft.³
  • Mechanical Compliance of Suspension (Cms)0.79 mm/N
  • BL Product (BL)7.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)16g
  • Maximum Linear Excursion (Xmax)4.25 mm
  • Surface Area of Cone (Sd)119 cm²
  • Cone MaterialPoly Composite
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.3"
  • Baffle Cutout Diameter5.512"
  • Depth2.72"
  • # Mounting Holes6
  • Sealed Volume0.26 ft.³
  • Sealed F374 Hz
  • Vented Volume0.7 ft.³
  • Vented F337 Hz
  • BrandMorel
  • ModelCAW 638
  • Part Number297-084
  • UPC844632066016
  • Product CategoryWoofers
    (4 Reviews)
  • Weight3.8 lbs.
View similar products to the Morel CAW 638 6" Cast Frame Woofer
