Morel CAW 538 5" Cast Frame Woofer
Brand:|Model: CAW 538|Part # 297-082
The Classic Advanced line of woofers is based on Morel's classic line - the renowned MW series. This woofer features an aerodynamic Uniflow™ open chassis, large diameter spider, reinforced ferrite magnets resulting in higher power handling, and low resonance frequency and Qts points.
List Price$160.99
You Save22%
$126.00
Part # 297-082
  • Uniflow™ aluminum diecast chassis
  • Large 3" Hexatech™ aluminum voice coil
  • High flux ferrite double magnet system
  • Shallow profile DPC cone
  • High power handling
The Classic Advanced line of woofers is based on Morel's classic line - the renowned MW series. These products have high power handling due to the aerodynamic Uniflow™ open chassis and large diameter spiders. This woofer has reinforced ferrite magnets for the double magnet system delivering higher magnetic flux motor, resulting in a low resonance frequency and Qts points. Latest evolution of Morel's MW-144.
  • Nominal Diameter5"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 3,500 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)49 Hz
  • DC Resistance (Re)5.2 ohms
  • Voice Coil Inductance (Le)0.47 mH
  • Mechanical Q (Qms)1.83
  • Electromagnetic Q (Qes)0.48
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.29 ft.³
  • Mechanical Compliance of Suspension (Cms)0.72 mm/N
  • BL Product (BL)6.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)14g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)90 cm²
  • Cone MaterialPoly Composite
  • Voice Coil Wire MaterialAluminum
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.3"
  • Baffle Cutout Diameter4.76"
  • Depth2.56"
  • # Mounting Holes6
  • Sealed Volume0.08 ft.³
  • Sealed F3103 Hz
  • Vented Volume0.19 ft.³
  • Vented F357 Hz
  • BrandMorel
  • ModelCAW 538
  • Part Number297-082
  • UPC844632066009
  • Product CategoryWoofers
    (3 Reviews)
  • Weight3.3 lbs.
View similar products to the Morel CAW 538 5" Cast Frame Woofer
