Momentary N.O. Metal Flat Flush Mount Push Button Switch
Brand:|Model: 66-2436|Part # 060-660
Heavy duty push button momentary switch. Specifications: • Current rating: 4A @ 125 VAC, 2A @ 250 VAC • Shaft diameter: 19 mm (3/4") • Contacts: 2.
List Price$8.99
You Save60%
$3.58
Buy 10-99 $3.44
Buy 100+$2.86
Part # 060-660
  • CircuitN.O.
  • Contact Rating @ Voltage4A 125 VAC
  • IlluminationNon-Illuminated
  • BrandParts Express
  • Model66-2436
  • Part Number060-660
  • UPC844632076046
  • Product CategoryPush-Button Switches
    (5 Reviews)
  • Weight0.01 lbs.
View similar products to the Momentary N.O. Metal Flat Flush Mount Push Button Switch
in the Push-Button Switches product category.
Momentary N.O. Metal Flat Flush Mount Push Button Switch is rated 4.8 out of 5 by 5.
Rated 5 out of 5 by from Excellent TransactionI received what I expected and am very satisfied with my purchase
Date published: 2015-06-03
Rated 5 out of 5 by from Nice button, but big!Switch has nice action and feels sturdy, but make sure you check the spec sheet for size!
Date published: 2014-11-10
Rated 5 out of 5 by from Perfect!I bought 5, only needed 1 and used all 5. They are great, high quality anti vandal style switches. I will be purchasing more for my electronics projects.
Date published: 2014-10-13
Rated 5 out of 5 by from Well madI was pleasantly surprised by the quality of the switch. I guess I am used to the really cheap ones at the auto parts store.
Date published: 2012-07-17
Rated 4 out of 5 by from Its a switchMaybe a little bit pricey, but it seems to be solidly built, does what its supposed to do
Date published: 2010-04-03
  • 2016-02-13T07:14CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_060-660, PRD, sort_mostRecent
What is the diameter of the switch. I am mounting the switch in an aluminum box so I have to make sure its width is not too big. Also, what size should the mounting hole be? I looked at the dimensions but I could not accurately read them. Thank you
Asked by: ZetaVape
You can see a tech drawing for the switch in the link below.http://www.parts-express.com/pedocs/tech-diagrams/060-660-parts-express-66-2436-tech-drawing-40674.jpg
Date published: 2015-10-05
I'm using this switch in a dc voltage application. What would the amperage limit be with dc current? It's only 4 volts dc, but the amperage could reach as high as 40 in my case.
Asked by: Marcus30
We do not recommend a current rating any higher than 4 amps for this switch.
Date published: 2014-10-06
Hi, I ordered this button and I'd like some more measurement for it if you can. I would like to know the width of the head, the depth of the head (so I can drill out a hole to make this fit flush), and how long the entire button is. Thanks!
Asked by: abosler
A dimensional drawing for this button can be found below.http://www.parts-express.com/pedocs/tech-diagrams/060-660-parts-express-66-2436-tech-drawing-40674.jpg
Date published: 2014-10-01
How far down does the button have to be pressed to make contact.
I would like to use these buttons for a MIDI drum machine and wanted to know how sensitive these buttons are.
Asked by: Scornil01
The switch needs to be depressed roughly 1/8" before contact is made.
Will this work with a 24VDC system?
I am interested in using a momentary switch to temporarily display a voltmeter connected to a 24VDC sealed lead acid battery. I'd like the voltmeter to display the voltage when I press the momentary switch. Just wondering if this switch will work in this application.Thanks
Asked by: DJStronkinson
Yes, this will handle voltages from 0-250 without an issue.
Dimensions?
What are the dimensions of the switch? It says the shaft diameter, but what's the diameter of the lip at the top if I want to countersink it? Thanks.
Asked by: ChrisG
The diameter of the lip is 22mm, the thickness of the lip is 1mm.
  • 2016-02-13T07:59CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_060-660, PRD, sort_recentQuestionsFirst
