Momentary N.O. Classic Large Push Button Switch Red
Brand:|Model: 66-2410|Part # 060-638
Push button momentary switch. Specifications: • Current rating: 3A @ 125 VAC, 1A @ 250 VAC • Shaft diameter: 12 mm (15/32") • Contacts: 2 • Approval: TUV, CE.
List Price$3.99
You Save75%
$0.98
Buy 10-99 $0.75
Buy 100+$0.60
Part # 060-638
  • CircuitN.O.
  • Contact Rating @ Voltage3A 125 VAC
  • IlluminationNon-Illuminated
  • BrandParts Express
  • Model66-2410
  • Part Number060-638
  • UPC844632075957
  • Product CategoryPush-Button Switches
  • Weight0.01 lbs.
View similar products to the Momentary N.O. Classic Large Push Button Switch Red
in the Push-Button Switches product category.
Is this switch rated for a high number of operations?  I want to use this on a controller interface and it is going to get pounded on a good bit.  I'd like to know it is durable.
Asked by: Robert Green
I need a spring loaded switch that can work with a small battery, aa or 9v,, instead of being activaded when push down. is need to be activated when the spring has a small enough amount of weight on it and is activated when up, Do you have this?
Asked by: movin247
I think what you want is a "normally closed" switch which means that without pressing anything, the contacts remain 'closed' or connected. In other words, the switch will pass a current/signal without pressing down on the button. When you press the switch down, it breaks the connection and "opens" the contacts. This switch should do the trick: http://www.parts-express.com/momentary-nc-classic-small-push-button-switch-black--060-634
Answered by: TomZ
Date published: 2016-01-03
Is this compatible with the Parts Express switch cover?  http://www.parts-express.com/switch-cover-red--060-582
Asked by: Jeremy3
Yes.
Answered by: TomI
Date published: 2015-11-12
Length of the threaded portion. Trying to mount these in 3/16th peg board.
Asked by: BESTCo
The length of the thread is 8mm.
Date published: 2014-05-05
What is the diameter of the button?
Asked by: portanav
The diameter of the button is 14mm or 0.55".
Date published: 2014-04-21
  • 2016-02-05T07:12CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_060-638, PRD, sort_recentQuestionsFirst
