MIPRO MA-100du (6A) Dual-Channel Portable Personal Wireless Rechargeable PA System w/USB Play/Record
Brand:|Model: MA-100du (6A)|Part # 247-318
Don't let the compact size of this highly portable personal sound system fool you. Lightweight, robust, and completely wireless, it can be carried via the built-in handle or shoulder strap, or mounted on a standard microphone stand to increase the volume of your voice in virtually any situation.
  • Rugged yet lightweight - just over 4 lbs.
  • Diversity receivers for reliable operation and range
  • User-friendly controls, quick and easy setup
  • Up to 12 hours run time per 4 hour charge
Frequently Bought Together
The MA-100 line of portable personal PA systems from MIPRO is ideal for use in classrooms, day-care facilities, playgrounds & parks, corporate meetings, seminars & presentations, and places of worship. Also the perfect problem solver for paging, tour guides, first responders, street/festival performers, marching bands, cheerleaders, rallies & demonstrations, law enforcement, search & rescue, fitness instructors, shopping center presentations, graveside services & receptions, or virtually any indoor/outdoor location where high quality voice amplification is needed, but a full-scale public address system is impossible, impractical, or simply inconvenient.
The ultra-light, ultra-compact, and ultra-portable MA-100 is available in three different frequency bands (6A, 6B, and 6C), so multiple units may be used in the same area without interference. The MA-100 is also available in either single or dual receiver configurations (designated "s" or "d" in the model number), and offers the option of a built-in USB MP3 player and recorder (designated "su" or "du"). Add the wireless transmitter(s) of your choice; use a typical handheld microphone, or a bodypack transmitter with a lavalier or headset microphone, depending upon your specific needs and preference. With the optional MSF4 instrument cable, you can even play your electric guitar through the system (with the appropriate bodypack transmitter). With dual receiver units, you may mix and match from among the various transmitters at your discretion. All these options make the MA-100 a superior solution for almost any size group, from one presenter with a small audience, up to very large and diverse settings where more than one audience and/or speaker may be participating simultaneously.
The MA-100 features a powerful yet lightweight Class-D amplifier, providing 50 watts of power for loud and clear projection of sound. The one-touch Scan and ACT™ sync system automatically finds the clearest operating frequency (among 16 scannable frequencies), and syncs the transmitter and receiver quickly, and hassle-free. The rechargeable battery lasts up to 12 hours on a single charge, and the 4-segment LED battery indicator makes it easy to see how much power is left at a glance. The unit can also run on standard AC power when it's convenient to do so. There is a handy 3.5 mm line input for external sources such as iPods, cell phones, or what have you, and a 3.5 mm line output for recording to external devices. The MA-100 also includes a 1/4" microphone input for one wired dynamic microphone (not included). A built-in alarm siren rounds out the impressive feature set, allowing the user to provide emergency warnings to a large area.
When you need quality public address on the go, look no further than MIPRO.
Specifications: • Model: MA-100du • Receiver capability: two (2) microphones and/or bodypacks • USB media player and recorder: Yes • Output power: 50 watts maximum • Frequency response: 50 - 18,000 Hz • Typical run time: variable depending upon usage pattern; up to 12 hours standby • Recharge time: 4 hours • Battery type: rechargeable lithium, 14.8V/2.6Ah • Dimensions: 5.3" x 5.5" x 9.4" (135 x 140 x 240 mm) • Weight: approx. 4.1 lbs. (1.9 kg).
Compatible Mics / Transmitters: ACT-30H (6A) handheld dynamic (#247-330) • ACT-30T (6A) mini-XLR bodypack (#247-336).
  • BrandMIPRO
  • ModelMA-100du (6A)
  • Part Number247-318
  • UPC848864007540
  • Product CategoryPortable PA Sound Systems
  • Weight4.1 lbs.
View similar products to the MIPRO MA-100du (6A) Dual-Channel Portable Personal Wireless Rechargeable PA System w/USB Play/Record
in the Portable PA Sound Systems product category.
