Middle Atlantic RLNK-SW715R RackLink 15A Power Switch w2-Sta
Middle Atlantic RLNK-SW715R RackLink 15A Web-Enabled Power Monitor / Switch
Brand:|Model: RLNK-SW715R|Part # 262-4102
The RLNK-SW715R is one of the RackLink™ family of products: a web-enabled power monitoring/management system that sets up in less than 5 minutes, and tracks the power and thermal conditions of your rack system. It can log and alert you to problems, reboot power automatically, and much more.
ORDER TODAY
Ships in 7-10 Business Days
List Price$1,057.00
You Save25%
$792.75
Buy 4+$753.11
Part # 262-4102
  • Quick & easy setup, virtually plug-n-play
  • Monitor and log key environmental variables
  • Set up instant notifications triggered by anomalies
  • Proactive & automatic fault resolution
  • Integrated web server provides browser-based access and control
  • Free smartphone application available
Frequently Bought Together
The RLNK-SW715R is a simple, intuitive monitoring and diagnostic device that allows the installer or contractor to identify power and thermal issues in virtually any system (up to 15A total load). With documented diagnostic information from the RLNK-SW715R in hand, you can recommend the best solutions to your clients with ultimate confidence, and since the RLNK-SW715R is designed for permanent or semi-permanent installation, you can keep monitoring and controlling the system 24/7 from anywhere with an internet connection. The RLNK-SW715R is one of several 1U offerings in the RackLink™ line, featuring seven total outlets, five of which are fully controlled, four pairs of controlled dry contacts, and robust 2-stage surge protection.
With Middle Atlantic's new RackLink™ line of products it's quick and easy to gather information about your rack environment, and make that information available night or day, locally, or remotely via web integration, from a web browser or even your smartphone. You can monitor your system's conditions in real time from literally anywhere in the world with internet access, and manage most options from the same simple interface. You can also be alerted via email, engage dry contact actions (on select models), engage or disengage selected outlets (on select models), or set the system to reboot when certain conditions are met, thresholds exceeded, and so forth.
Some variables which are monitored and logged include:
• Input voltage (Peak & RMS) • Load current (Peak & RMS) • Temperature • Surge status • Connected load (Watts/real time) • Cumulative load (kWh/historical) • Power factor • Thermal load
These variables are logged every five minutes (or immediately on alert conditions), and can be easily viewed on-site, or extracted by by a control system via RS232 or IP protocols using Middle Atlantic's API (custom drivers available for a growing number of popular control systems). You can also set thresholds or conditions that will engage dry contacts, send email notification, reboot power, and more. This can be not only very slick and handy, but also save you lots of money by protecting your equipment during an alert situation. For instance, you can set the system to engage additional cooling equipment, or to disengage certain heat-generating equipment in your rack if the temperature reaches a specified level. You can have the system notify you via email on such triggers, and you can decide what action to take. With the RackLink™ Power Management System, the power is in your hands. You can keep it as simple as you wish, or take your entire system to a new level of protection and reliability. It's up to you.
  • Number of Outlets7
  • Special FeaturesRack Mountable
  • Cord Length9 ft.
  • ColorBlack
  • BrandMiddle Atlantic
  • ModelRLNK-SW715R
  • Part Number262-4102
  • UPC656747179235
  • Product CategoryRack Mount Power Distribution
  • Weight10.13 lbs.
View similar products to the Middle Atlantic RLNK-SW715R RackLink 15A Web-Enabled Power Monitor / Switch
in the Rack Mount Power Distribution product category.
Videos
