262-686_ALT_0
262-686_ALT_1
262-686_ALT_2
262-686_ALT_3
Middle Atlantic FAN 4-5/8" x 1-1/2" Fan 95 CFM 115 VAC
Brand:|Model: FAN|Part # 262-686
Featuring a smooth, ball-bearing design, this 4-5/8", 115V fan is perfect for use with the FP series fan panels, or on rack system tops that are designed to accommodate 4-5/8" fans. 95 CFM air flow.
List Price$69.00
You Save25%
$51.75
Buy 4+$49.16
Part # 262-686
  • Impeller : Polycarbonate (glass fiber-containing), 5-blade
  • Bearing: Ball bearing
  • Motor: 115 VAC, 50/60 Hz, 15/13W, impedance protected
  • Casing: Aluminum
  • 95 CFM air flow, 2750 RPM, 39 dBA noise rating
Featuring a smooth, ball-bearing design, this 4-5/8", 115V fan is perfect for use with the FP series fan panels, or on rack system tops that are designed to accommodate 4-5/8" fans. 39 dBA free air noise rating. 95 CFM air flow. 2750 RPM speed. Lead wire: 22 AWG, UL3266, CSA CLR52 or Terminal: Faston #110 or equivalent. Includes mounting hardware and power cord.
Specifications: • Dimensions: 119 x 119 x 38 mm • Middle Atlantic model# FAN. Mfg Model Number 4715MS-12T-B40.  NMB-MAT
  • Operating Voltage110~120 VAC
  • Size120 mm
  • Bearing TypeBall Bearing
  • BrandMiddle Atlantic
  • ModelFAN
  • Part Number262-686
  • UPC656747007057
  • Product CategoryEquipment Cooling
    (7 Reviews)
  • Weight1.3 lbs.
View similar products to the Middle Atlantic FAN 4-5/8" x 1-1/2" Fan 95 CFM 115 VAC
in the Equipment Cooling product category.
