Metra 99-3900 GM/Chevy/Pontiac/Olds 1994-Up Multi-Kit
Brand:|Model: 99-3900|Part # 265-843
Turbokits from Metra...a quick and simple way to install an aftermarket radio in the original factory radio's location. Multi-kit for Chevrolet 1994-Up, GMC 1998-Up, Isuzu 1998-Up, Oldsmobile 1997-Up, Pontiac 1997-Up.
Turbokits™ from Metra...a quick and simple way to install an aftermarket radio in the original factory radio's location. Multi-kit for Chevrolet 1994-Up, GMC 1998-Up, Isuzu 1998-Up, Oldsmobile 1997-Up, Pontiac 1997-Up Quick conversion from 2-shaft to DIN Turbokits are uniquely designed to provide a combination of strength, appearance and versatility. Because Turbokits are made from ABS plastic they can be easily modified for custom jobs. The faceplates are designed to fit the dash opening perfectly with no gaps, and DIN radio ISO mounts are included in as many Turbokits as possible. A Turbokit's brackets are designed to emulate the factory radio brackets, making the installation of an aftermarket radio the fastest in the business.
Note: Except for vehicle specific kits, Turbokits are designed for multiple applications and fit multiple car models perfectly. Likewise, many vehicle makes and models have multiple kit options available. Although your specific year, make or model may not be listed above, if the Metra Installation Kit Wizard directed you to this item, then this kit is designed for use with your vehicle.
  • BrandMetra
  • Model99-3900
  • Part Number265-843
  • UPC086429033140
  • Product CategoryRadio Dash Mounting Kits
  • Weight0.8 lbs.
View similar products to the Metra 99-3900 GM/Chevy/Pontiac/Olds 1994-Up Multi-Kit
in the Radio Dash Mounting Kits product category.
