320-315_ALT_0
320-315_ALT_1
Mean Well MW NES-350-12 12 VDC 29A 348W Regulated Switching Power Supply
Brand:|Model: NES-350-12|Part # 320-315
This large 12 volt DC, 29 amp regulated power supply is capable of supporting amplifiers with up to 348 watts of output. Adjustable 10 to 13.5 volts DC output and switchable 90-264 volts AC input. UL recognized design.
List Price$69.99
You Save29%
$49.90
Buy 4+$47.98
Part # 320-315
  • Supplies up to 348W of power
  • Up to 83% efficient
  • Adjustable output of 10 to 13.5 VDC for amp boards and car audio equipment
  • UL recognized, regulated output with forced air cooling
  • World compatible 90 to 264 VAC input voltage
Large amplifiers require large power supplies, and they don't get much larger than this! With a regulated output of 12 volts DC (which can be adjusted from 10 to 13.5V DC), and current capacity of 29 amps, this power supply is the perfect partner for amplifier boards and car audio equipment with of up to 348 watts of output on tap.
Voltage input can be switched for use with 110 or 240 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Forced air cooling regulates temperature internally. Power supply cable and output cable included. UL recognized design.
Note: Minimum recommend power wire gauge is 16 AWG.
• Input power: Switchable between 90-132 VAC and 180-264 VAC, 47-63 Hz
• Maximum current consumption: 7A @ 115 VAC, 4A @ 230 VAC
• Output power: 12 VDC, 29A
• Adjustable output voltage range: 10~13.5 VDC
• Efficiency: 83%
• Dimensions: 8.5" L x 4.5" W x 2" H
  • BrandMean Well
  • ModelNES-350-12
  • Part Number320-315
  • UPC844632099748
  • Product CategoryPower Supplies
    (15 Reviews)
  • Weight2.35 lbs.
View similar products to the Mean Well MW NES-350-12 12 VDC 29A 348W Regulated Switching Power Supply
in the Power Supplies product category.
