Mean Well MW LVP-60-12 12 VDC 5A Water Resistant AC Adapter IP67 Wire Leads
Brand:|Model: LVP-60-12|Part # 320-3146
This 12 volt DC, 5 amp regulated power supply is capable of up to 60 watts of power in nearly any environment due to its IP67 water-resistant design.
List Price$59.99
You Save58%
$24.90
Buy 4+$23.50
Part # 320-3146
  • IP67 rated chassis for use in wet environments
  • 12 VDC regulated output with 5A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Perfect for use with up to 5 meters of SMD 5050 or SMD 3528 LED lighting strips
  • World compatible AC input
This switching power supply is ideally suited for use with LED lighting. With a regulated output of 12 volts DC, and current capacity of 5 amps, this power supply is the perfect partner for up to five meters of SMD 5050 or SMD 3528 LED lighting strips. The fully encapsulated IP67-rated case allows this power supply in nearly any environment due to its dust-free design and ability to be immersed in water up to 1 meter.
Power input is world compatible and able to work with anywhere from 100 to 240 volts AC input. Each power supply is 100% full load burn-in tested and can handle up to a 300 VAC surge for 5 seconds. Two mounting tabs and 23" long input and output leads facilitate permanent mounting. Edison style power cord required and sold separately. CE rated design.
Specifications: • Input power: 100-240 VAC, 47-63 Hz • Output power: 12 VDC, 5A • Dimensions: 6.4" L x 1.67" W x 1.26" H.
  • BrandMean Well
  • ModelLVP-60-12
  • Part Number320-3146
  • UPC848864002651
  • Product CategoryPower Supplies
  • Weight0.88 lbs.
View similar products to the Mean Well MW LVP-60-12 12 VDC 5A Water Resistant AC Adapter IP67 Wire Leads
in the Power Supplies product category.
