Buyout Special
259-210_ALT_0
Mabuchi Motor RS-555PH 12V DC Motor (9~20V) 57mm x 36mm
Brand:| Model: RS-555PH
This robust DC motor from Mabuchi is perfect for any number of electronic projects, including modelling, R/C, and robotics.
  • Low torque ripple for accurate and consistent speed
  • High speed – 5560 rpm with no load
  • Wrap-around shield reduces electrical interference
259-210
Weight: 0.45 lbs.
IN STOCK
List Price$9.99
Regular Price$7.00
You Save53%
Special Price
$3.25
Buy 10-99 $2.90
Buy 100-up$2.29
Part # 259-210
The RS-555PH from Mabuchi Motor is a stout DC motor useful as a common replacement for old style reel to reel tape decks by Akai and Teac. Originally offered as an OEM motor for ink jet printers and electric drills. Can also be used for many hobbyist projects such as radio controlled vehicles, robotics, model-building, home automation, and more! The 5-pole construction utilizes permanent magnets, so the motor produces high torque with high efficiency. Mounting is simplified by three 3 mm mounting holes on the face of the motor.
Specifications: • Speed (without load): 5560 rpm • Speed / Torque: 3950 rpm / 380.3 g–cm • Stall torque: 1360 g–cm • Current draw (at 5000 rpm): 1.25A • Nominal voltage: 12 VDC • Direction - Clockwise • Operating voltage: 7 to 12 VDC • Weight: 36 g • Shaft diameter: 3.0 mm • Shaft length: 10.5 mm • Dimensions: 37.5 mm x 57 mm.
  • BrandFactory Buyouts
  • ModelRS-555PH
  • Part Number259-210
  • UPC848864000428
  • Product CategoryMotors
    (3 Reviews)
  • Weight0.45 lbs.
View similar products to the Mabuchi Motor RS-555PH 12V DC Motor (9~20V) 57mm x 36mm
in the Motors product category.
Mabuchi Motor RS-555PH 12V DC Motor (9~20V) 57mm x 36mm is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Works great.I bought this motor because it's part number matched the rusty & locked up trim motor on my 1994 Polaris SL 750 water craft. It was a perfect match and works great. You can't beat the price.
Date published: 2014-04-15
Rated 5 out of 5 by from Mabuchi motors are very good.I remember back in the late 80's playing with these motors and noticing their high quality and were VERY expensive.Can't go wrong with these. They were used in the high end R/C cars, trucks, etc toys and still are! Wonder why? :)
Date published: 2014-01-13
Rated 5 out of 5 by from cool toyThese things are strong! Running off a 12v 1.5 amp power supply, I can't grab it strong enough to stop it...or really even slow it down much, and I have pretty strong fingers.Great for car or solar projects. I made a solar powered tent ventilator that actually works for a change and another one for the car the dog loves!My 10 year old has an idea for an R/C crane....and with these for power I'm sure will lift real bricks!These are the perfect thing for us tinker/thinkers to help pass a long winter, or just a good excuse to hide from the wife and kids for a while! Where else except Parts Express can you spend so little for a whole lotta fun!
What is the armature inductance ?for theMabuchi Motor RS-555PH 12V DC Motor
Asked by: mahaya01
Unfortunately the manufacturer did not provide this information to us for this buyout item.
Date published: 2014-04-10
What potentiometer should I use
I am looking for a potentiometor to reduce the 12vdc 3.5amp power to a variable 0-1.25 amp. Will a potentiometer do this?
Asked by: RobFredrickson
You "could" control a DC motor with a variable resistor (a potentiometer). While the latter approach works well, it generates heat and hence wastes power.That being said. 12VDC @ 3.5 amps is about 42 watts.The only pot I know of that can dissapte that much power is a high power "L pad". A 50 watt should do the trick, and Parts Express has them.....BUT....As the voltage is absorbed, the motor also looses power as it slows down so you might not end up with a very useful power curve...and L pads aren't ultra cheap.A better bet?A simple pulse width modulation DC motor control eliminates these problems. It controls the motor speed by driving the motor with short pulses ...of "full" power so the strength of the motor isn't affected. Only the speed. Nice!With this kind of circuit, the pulses vary in duration to change the speed of the motor. The longer the pulses, the faster the motor turns, and vice versa....and the parts a pretty cheap.You can find examples with circuit layouts pretty much everywhere. UTube has many good videos, and of course Parts Express has the parts too.Good luck!
Answered by: Gerry L.
Customer projects that include: Mabuchi Motor RS-555PH 12V DC Motor (9~20V) 57mm x 36mm
