259-210_ALT_0
Mabuchi Motor RS-555PH 12V DC Motor (9-20V) 57mm x 36mm
Brand:|Model: RS-555PH|Part # 259-210
This robust DC motor from Mabuchi is perfect for any number of electronic projects, including modelling, R/C, and robotics.
Part # 259-210
  • Low torque ripple for accurate and consistent speed
  • High speed – 5560 rpm with no load
  • Wrap-around shield reduces electrical interference
The RS-555PH from Mabuchi Motor is a stout DC motor useful as a common replacement for old style reel to reel tape decks by Akai and Teac. Originally offered as an OEM motor for ink jet printers and electric drills. Can also be used for many hobbyist projects such as radio controlled vehicles, robotics, model-building, home automation, and more! The 5-pole construction utilizes permanent magnets, so the motor produces high torque with high efficiency. Mounting is simplified by three 3 mm mounting holes on the face of the motor.
Specifications: • Speed (without load): 5560 rpm • Speed / Torque: 3950 rpm / 380.3 g–cm • Stall torque: 1360 g–cm • Current draw (at 5000 rpm): 1.25 A • Nominal voltage: 12 VDC • Direction - Clockwise • Operating voltage: 7 to 12 VDC • Weight: 36 g • Shaft diameter: 3.0 mm • Shaft length: 10.5 mm • Dimensions: 37.5 mm x 57 mm.
  • BrandFactory Buyouts
  • ModelRS-555PH
  • Part Number259-210
  • UPC848864000428
  • Product CategoryMotors
    (7 Reviews)
  • Weight0.45 lbs.
View similar products to the Mabuchi Motor RS-555PH 12V DC Motor (9-20V) 57mm x 36mm
in the Motors product category.
