Microphone/Signal Cable 100 ft.
Low Noise Microphone Instrument Signal Cable Copper Braid 22ga Black 100 ft. USA
High quality, commercial grade microphone cable that's perfect for building your own! Features two 22 ga. center conductors (as opposed to 24 ga. found in many competitors' cables) for lower resistance and maximum signal transfer. Made in the USA.
100-225
Weight: 4.09 lbs.
IN STOCK
List Price$69.99
You Save32%
$47.50
Buy 4-up$43.85
Part # 100-225
Qty:  RL
High quality, commercial grade microphone and small-signal cable that's perfect for building your own! Also for making high quality low noise RCA patch cables. Features two 22 ga. center conductors (as opposed to 24 ga. found in many competitors' cables) for lower resistance and maximum signal transfer. Super durable, yet flexible black PVC outer jacket. Available in custom lengths, or buy it on spools and save.
Specifications: • Conductors: 2 x 22 ga. (65 x 40 ga.) • Insulation colors: Black and white • Shield: 92% coverage bare copper braid • Jacket: Black PVC, 6.4 mm (.252") O.D. • 100% satisfaction guaranteed • Made in the USA.
  • Wire Gauge22 AWG
  • Jacket ColorBlack
  • Length100 ft.
  • BrandParts Express
  • Part Number100-225
  • UPC844632045424
  • Product CategoryMicrophone Cable & Signal Cable
  • Unit of MeasureRL
    (11 Reviews)
  • Weight4.09 lbs.
View similar products to the Low Noise Microphone Instrument Signal Cable Copper Braid 22ga Black 100 ft. USA
in the Microphone Cable & Signal Cable product category.
Low Noise Microphone Instrument Signal Cable Copper Braid 22ga Black 100 ft. USA is rated 4.1818 out of 5 by 11.
Rated 5 out of 5 by from Good cable for the moneyThis is the second time I buy this cable and I like the way it's made. Nice shield and the 22 gauge wire is good to work with and solder. A lot of the pre-made cables are 24 gauge with less shielding. I used this to make 50 and 30 foot cables. I expect they will last me a while.
Date published: 2014-04-07
Rated 4 out of 5 by from Good cable for the moneyThis looks great on paper, and the price is somewhat reasonable too. The 22 gauge is nice. The nylon filling inside is nice too. I definitely appreciate the braiding shield over a straight stranded copper shield. The jacket is super thick. Overall, from the outside, it looks like a great cable.Of course, no product is perfect. The braiding and the overall copper is definitely not OFC. It is not nearly as shiny as the other cables I've tried in the past. This requires me to pay a little bit more attention when I make cables to seal the copper before I put the connector together. The oxidation is also apparent with solder, as the solder doesn't adhere as well as OFC wires.Overall, I'd have to say this product isn't perfect, and isn't quite bad for the money. I think for next time, I'd spend just a little bit more for a better cable.
Date published: 2014-01-14
Rated 5 out of 5 by from awesome quality cable,very workable in snug places where there are bends,
Date published: 2013-12-21
Rated 4 out of 5 by from Nice quality cableI build a 40' cable with this and it was excellent, quiet and had about an ohm of resistance for each of the 2 signal conductors. nice to work with, solders well, with a very dense copper braid. I feel like dumping all my old cables. 22 gauge is important for longer cable lengths and night after night usage being wraped and dragged across the stage. It's just overall a nice fairly robust cable. I definitely will buy more.
Rated 5 out of 5 by from Professional Cable for the money!!!.......This is great cable for the money! The jacket is very heavy duty. The lead wires are a little smaller guage, but, if you strip them properly, (i use a sharp razor blade, put two slits in the jacket, pull off with your finger nails, tin, your goodto go!!!). Do not over heat the lead wires, you will melt the jacket. use just enough to flow to the solder joint. (solder). THANKS PARTS EXPRESS!!!!!!!........
Rated 4 out of 5 by from Good quality cable at a decent priceI've tried Mogami Neglex cables and actually like these better. Good quality at a decent price.
Customer projects that include: Low Noise Microphone Instrument Signal Cable Copper Braid 22ga Black 100 ft. USA
