LM4780TA Overture Audio Power Amp IC TO-220 27 Pin
Brand:|Part # LM4780
The LM4780TA is a stereo audio amplifier capable of typically delivering 60W per channel of continuous average output power into an 8 ohm load with less than 0.5% THD+N from 20 Hz-20 kHz.
  • SPiKe Protection
  • Low external component count
  • Signal-to-Noise Ratio >= 97 dB
  • Quiet fade-in/out mute mode
  • 27-lead TO-220 package
  • Wide supply range: 20V-84V
The LM4780TA is a stereo audio amplifier capable of typically delivering 60W per channel of continuous average output power into an 8 ohm load with less than 0.5% THD+N from 20 Hz-20 kHz. The LM4780TA is fully protected utilizing National's Self Peak Instantaneous Temperature (°Ke) (SPiKe™) protection circuitry. SPiKe provides a dynamically optimized Safe Operating Area (SOA). SPiKe protection completely safeguards the LM4780TA's outputs against over-voltage, under-voltage, overloads, shorts to the supplies or GND, thermal runaway and instantaneous temperature peaks. The advanced protection features of the LM4780TA places it in a class above discrete and hybrid amplifiers. Each amplifier of the LM4780TA has an independent smooth transition fade-in/out mute. The LM4780TA can easily be configured for bridge or parallel operation for 120W mono solutions. Examples of applications include amplifier for component stereos, compact stereos, self-powered speakers, surround-sound amplifiers, high-end and HD TVs, etc.
  • BrandParts Express
  • Part NumberLM4780
  • UPC844632054440
  • Product CategoryIntegrated Circuits ICs
    (1 Reviews)
  • Weight0.08 lbs.
TDA2020 Intergated Circuit
Part #  TDA2020
NE555P Timer IC
Part #  NE555
LM555 Timer IC (8 Pin DIP)
Part #  LM555
View similar products to the LM4780TA Overture Audio Power Amp IC TO-220 27 Pin
in the Integrated Circuits ICs product category.
