071-585_ALT_0
Littelfuse Add-A-Circuit Fuseholder for Mini Fuses
Brand:|Part # 071-585
This ingenious device allows quick and easy installation of additional accessories without the need for splicing. For use with Mini Knife fuses. Includes installation instructions. Max rating: 10 amps.
List Price$19.99
You Save36%
$12.75
Buy 4-99 $11.50
Buy 100+$10.50
Part # 071-585
This ingenious device allows quick and easy installation of additional accessories without the need for splicing. To use this fuse tap simply remove a fuse from your fuse box and install the original fuse in the first slot of the tap. Then install a fuse of your choice in the second slot. This fuse will be used to limit current to the wire tap while the original fuse will still protect the other accessories on the circuit. Then install the add-a-fuse into the original fuse location in the box. For use with Mini Knife fuses. Includes installation instructions. Max rating: 10 amps.
  • BrandLittelfuse
  • Part Number071-585
  • UPC079458035094
  • Product CategoryAutomotive Fuse Holders
    (26 Reviews)
  • Weight0.04 lbs.
View similar products to the Littelfuse Add-A-Circuit Fuseholder for Mini Fuses
in the Automotive Fuse Holders product category.
Littelfuse Add-A-Circuit Fuseholder for Mini Fuses is rated 4.4615 out of 5 by 26.
Rated 5 out of 5 by from Time saverThis is a very easy way to hardwire a low-amperage device such as LED lighting, a GPS, or radar detector. I used mine in an empty fuse socket just so I could front-wire the device. Keep in mind you will need two fuses in the holder, even if no circuit is connected behind the fuse box.
Date published: 2013-08-10
Rated 5 out of 5 by from The product worksI used the product to connect an accessory item in my car and it works as advertised. I would like to add when I called the company the person I talked to was very friendly and helped me select the right product for my need.
Date published: 2010-08-26
Rated 5 out of 5 by from Excelent prduct and qualityI managed to install a NUVI in a MiniCooper without cuttig any wires. But with a fuse. I was able to use a fuse that is switched with the ignition key. Excelente product.
Date published: 2010-03-28
Rated 5 out of 5 by from What a great idea!This is one of the neatest things I have come across!
Date published: 2010-01-27
Rated 5 out of 5 by from does what they say, but not by the directionsThis product is AWESOME. After a 10 minute install into a Honda S2000, I had exactly what I wanted. The instructions state that there is a 10a max, but I had to use two 10a fuses for anything to work, plugged into my 10a fuse slot. To reiterate, I used both the supplied 10a fuse and the original 10a fuse and added a second power outlet under my dash.
Date published: 2009-09-19
Rated 5 out of 5 by from Perfect for the jobUsed it to install a separate power source for an XpressRC XM Satellite Receiver in an '09 MiniCooper. Worked as advertised, no problems.Receiver is spec'ed at 10W, or < 1A @ 12V, so a 3A fuse was plenty for the additional circuit.
Date published: 2009-08-02
  • 2016-02-06T07:47CST
  • co_hasreviews, tv_0, tr_26
  • loc_en_US, sid_071-585, PRD, sort_mostRecent
I would like to get this with out the 90 turn. A strait up nini fuse piggy back holder. I do not have room for the sideway mount. Do they make one? thanks jw
Asked by: jw reed
We only have this available with the angled male end.
Date published: 2015-10-06
Hooking up a radar detector with two leads Hot and Ground. found a fuse for the ignition, but what do I do with the ground wire. Can I hook it to any metal ground???? thank you Steve
Asked by: horvy
Yes the ground connection gets wired to any grounding point in the vehicle.
Date published: 2015-03-11
  • 2016-02-06T08:34CST
  • loc_en_US, sid_071-585, PRD, sort_recentQuestionsFirst
