310-298_ALT_0
310-298_ALT_1
310-298_ALT_2
310-298_ALT_4
Lepai LP7498E 200W Class D Digital Amplifier with Bluetooth and Power Supply
Brand:| Model: LP7498E
Product Video
Lepai's LP7498E 200 watt Class D amplifier features wireless Bluetooth technology, combining usability with power.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
  • 200 watt Class D amplifier
  • Bluetooth connection for wireless music streaming
  • Compact size is perfect for home audio or multimedia systems
  • Power supply included
310-298
Weight: 3 lbs.
IN STOCK
List Price$199.99
Regular Price$99.90
You Save11%
Sale Price
$88.88
Part # 310-298
Look no further, the Lepai LP7498E amplifier delivers a clean 200 watts from one of the most efficient Class D amplifiers in history! Use the Bluetooth connection to wirelessly stream audio from your iPhone, Android smartphone, tablet, or laptop. With 100 watts per channel, this stereo amplifier is perfect for desktops, bookshelf speakers, and most home audio applications. The black chassis and a laser engraved silver faceplate provide a very attractive, modern finish.
High quality binding posts (5/8" on center) accept bare wire, 3/8" spade terminals, or standard banana plugs for problem-free speaker connections. RCA L/R inputs for analog connection (cable not included). Includes 36 VDC 4.5A power supply.
Specifications:  • Power output (10% THD): 2 x 160 watts into 4 ohms, 2 x 120 watts into 6 ohms, 2 x 100 watts into 8 ohms • Amplifier efficiency: 90% • Minimum THD: <1% • Signal-to-noise ratio: >90 dB • Frequency response: 20-20,000 Hz • Bluetooth compatibility: Class 2 A2DP, AVRCP up to 20 meters • DC power input jack: 2.5 mm x 5.5 mm • Power requirements: 18 to 36 VDC, 4.5A • Included power supply: 36 VDC, 4.5A • Dimensions: 4-1/2" W x 7" D x 1-1/4" H.
  • Special FeaturesBluetooth
  • BrandLepai
  • ModelLP7498E
  • Part Number310-298
  • UPC848864006147
  • Product CategoryHome Audio Amplifiers
    (42 Reviews)
  • Weight3 lbs.
View similar products to the Lepai LP7498E 200W Class D Digital Amplifier with Bluetooth and Power Supply
in the Home Audio Amplifiers product category.
Lepai LP7498E 200W Class D Digital Amplifier with Bluetooth and Power Supply is rated 4.2381 out of 5 by 42.
Rated 5 out of 5 by from set up in secondsplugged it in switch to bluetooth up and running in under a minute Thanks Parts Express great product
Date published: 2014-10-20
Rated 4 out of 5 by from Good productI bought this a month ago and I am satisfied. Efficient and cheap !
Date published: 2014-10-14
Rated 5 out of 5 by from Tiny power, tiny price!I have this running a pair of Advent Heritage towers and it's more than enough in terms of clean power. The simple design makes it easy to switch between the analog input (which sounds wonderful) to the Bluetooth feed (which sounds, well, like Bluetooth).The volume knob feels a bit cheap but aside from that it's a solid amp with plenty of grunt for larger speakers.
Date published: 2014-10-06
Rated 4 out of 5 by from Lepai replacement is fineI put the original unit in service a few weeks ago and it ran hot and had limited output. The replacement unit put 66 watts rms into 8 ohms on the bench and I am very happy. I give Parts - express 5 stars for their handling of this situation.
Date published: 2014-10-01
Rated 4 out of 5 by from Perfect for overnight sensationsI bought this little amp for portability on trips with the intent of using some overnight sensations speakers. The first amp showed up DOA and appeared to have been a return that somehow made it back into stock. The amp smelled burned when removed from the packaging. I will say as disappointed as I was, Parts Express customer service took care of the situation as quickly as shipping would allow.As to how this amp sounds: simply awesome when paired to the overnight sensations. It has been said in other reviews and questions that it is probably not a true 100w x 2 amp but it sure does sound better than the Dayton DTA it replaced. The overnight sensations are not very efficient so I was looking for more power. I recently took the speakers and amp to a patio birthday party and people were extremely impressed by this small set up. Having the Bluetooth connection was extra handy for adjusting volume and skipping songs while sitting by the heater.I would like to have a volume knob that doesn't feel like piece off of a kids toy, and the Bluetooth antenna would be nice if it didn't flop around, but overall I am very happy with this amp. I hope it lasts!
Date published: 2014-09-15
Rated 4 out of 5 by from Petit, puissant et de qualitéJe ne suis pas déçu par cet appareil qui correspond bien à mes attentes.
Date published: 2014-09-12
Can I run this amp in mono configuration?
Asked by: Jag82
This amplifier is not bridgeable, but you can use only one channel. The output power will be no different however.
Date published: 2014-11-18
Hi! Can this amp be strapped for mono operation and do you think it would work in a live music application playing an upright bass through it?
Asked by: fretless5
I have a pair of polk audio atrium 4 speakers on a roof top deck and would like to know would this amplifier work with them? Does it provide enough power?
Asked by: omega609
Yes this amplifier will work well for four of those speakers.
Date published: 2014-11-10
Will this amplifier damage speaker 80 watt RMS at 4 ohm? http://www.pioneerelectronics.com/PUSA/Car/Speakers/D-Series/TS-D6902R
Asked by: Oakkey
No this amp will work fine with an 80 watt speaker. As long as you don't over drive the speaker itself at high volume levels you will have no problems.
Date published: 2014-10-27
I want a small amp to power 2 ceiling speakers in a bathroom coupled with a BT receiver (hidden in a cabinet). What are my best sound/quality option: Lepai LP7498E or AudioSource AMP102 with a dedicated high quality BT receiver? Money's not a factor...
Asked by: PC_Pal68
hello, can i use this little amp with 4ohm speakers? for example with the ft12 from http://www.lautsprecherbau.de thank you. chris
Asked by: tschiese
Yes this will work with 4 ohm speakers.
Videos
Customer projects that include: Lepai LP7498E 200W Class D Digital Amplifier with Bluetooth and Power Supply
Discussions in our TechTalk Forum that include: Lepai LP7498E 200W Class D Digital Amplifier with Bluetooth and Power Supply
