310-302_ALT_0
310-302_ALT_1
310-302_ALT_2
Lepai LP-A68 Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM
Brand:| Model: LP-A68
Up to 15 watts of stereo power are on tap with the Lepai LP-A68. Additionally you will find included features such as: built-in FM tuner with collapsible antenna, MP3 decoding with USB and SD/MMC input, IR remote control, four EQ functions, and tone controls. Power supply included.
  • All-in-one amplifier with SD/MMC card and USB input
  • Up to 2 x 15W of output
  • Power supply, IR remote, and FM antenna included
  • 4-ohm stable
  • 12 VDC power supply included
310-302
Weight: 1 lbs.
IN STOCK
List Price$39.99
You Save37%
$24.80
Buy 4-up$23.25
Part # 310-302
The Lepai LP-A68 combines an FM tuner, MP3 playback with SD/MMC card and USB support, and an IR remote control together with a minimum footprint stereo amplifier that can be used virtually anywhere!
Front mounted treble, bass, and volume controls, as well as a four function EQ with pop, jazz, classic, and rock settings (accessible via the remote control), allow you to dial in the sound to match your taste and get the most out of your speakers. A 12 VDC power supply is included, and a 9-1/2" long collapsible FM antenna is built-in, as are a set of stereo RCA inputs and a stereo 3.5 mm stereo input.
Specifications: • 2 x 15W RMS • Power requirements: 12 VDC • DC power input jack: 2.1 mm x 5.5 mm • Stable down to 4 ohms • Minimum THD: <1% • Signal-to-noise ratio: >80 dB • Frequency response: 20-20,000 Hz • Input impedance: 47k ohms • FM tuner frequencies: 87.5 to 108 MHz • FM receiver sensitivity: 16 dB • FM signal-to-noise ratio: 60 dB • Channel separation: 39 dB • Dimensions (including mounting flange): 6" W x 2-3/4" x 1-5/8" H.
  • Special FeaturesFM Tuner,USB Connectivity,SD Card Input,Remote Control
  • BrandLepai
  • ModelLP-A68
  • Part Number310-302
  • UPC844632089404
  • Product CategoryHome Audio Amplifiers
    (39 Reviews)
  • Weight1 lbs.
View similar products to the Lepai LP-A68 Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM
in the Home Audio Amplifiers product category.
Lepai LP-A68 Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM is rated 3.9744 out of 5 by 39.
Rated 5 out of 5 by from Really surprised.I got one of these to hook up to my sister's TV because the speakers on the TV were absolutely wretched. To be honest, I wasn't expecting much, nor was I expecting it to last very long. It has been running daily for over a year for hours at a time. We have had absolutely no problems with the unit. It sounds pretty good as well. I have it hooked up to the classic, and great sounding, Realistic Minimus speakers. It makes quite an awesome pair. Again, I am really surprised it.Of course, Parts Express was awesome. I live in Ohio and got it next day at regular shipping.
Date published: 2014-09-13
Rated 4 out of 5 by from Perfect for Flat TV sound improvbement!Finally my TV sound can match up to the picture. I have connected this amp from my Samsung flat screen TV ear phone jack and it sounds great. Plenty of volume from this amp without distortion. Using the earphone jack allows me to control the volume remotely by my TV remote. Using the RCA input jack, and the digital optical TV output requires I use my D to A converter, my TV does not control the volume this way neither does the remote control from this amplifier. Power on and off does work from the amp remote. Hope I do not have a damaged unit given the lack of volume control from the remote when the RCA jacks are used. O
Date published: 2014-05-22
Rated 4 out of 5 by from Great for background musicI purchased this amp to use in my preschool classroom as I play a large variety of music during the day. I wanted to have something to play MP3's on and be able to quickly change songs. The quality of sound is fine for what I'm using it for; I can see this unit excelling at being used for background music in the house or even a small business hooked up to a set of bookshelf speakers. It will play the songs on a SD card or jump drive all day long.Here is how I handled the music: I made a list of probably 40-50 songs numbered 1-50 as the name and put it on a SD card. The songs do play in order, but number 1 on my list isn't number 1 when I press the "1" on the direct entry keypad on the remote. So I get around this by listening to whatever song plays when I hit the play button, and adding or subtracting the number of songs on the list I printed out and pressing the "<" or ">" buttons that many times until I get to the song I want. It's a bit of work but it's not so bad. I don't know why I expected the player to recognize song number "1" as the first one, it's not a computer and doesn't work that way, but I didn't think that far ahead I guess when setting my SD card up.Well, a member on Tech Talk mentioned to me that I might try taking all the songs off the SD card and putting them all back on after reformatting the card which would hopefully make the first song on my card the #1 song so my numbered list of songs would match the list I had typed out on paper. I haven't given this a try yet, but plan to. I will report back with the results.Overall, this is a good unit. The sound is not as good as the Lepai 2020 amp that I have purchased 8-10 of in the past few years, that thing is kind of amazing, but it is fine for the classroom playing toddler songs. The fact that it also plays FM is kind of cool to. I can get a few stations in and it sounds pretty decent, better than expected. Quality of the MP3 songs is very nice.For the price, it's really a bargain I think for all that it does. The remote works across the classroom 25 feet away, and the unit is light enough that you can mount it anywhere. I made a small shelf which I screwed right into my bulletin board and then screwed the amp to using small self-tapping screws. I can press the buttons this way without having to hold the amp with my other hand -- it is very light.I would buy this again if I needed an all-in-one amp/mp3 player in the future.
Date published: 2014-04-21
Rated 5 out of 5 by from ALL features work wellHave 2 of these 6mos and 1 45W x 4 and 1 2.1 chan. All work very well and have plenty of power even with 8ohm speaker sets. Will play MP3 and wave from flash drives SD cards and MP3 players. I use all these and more on a whole house distributiton (line level) network (8 locations at present) These are not equal to the true audiophile systems on the network, but mighty close. An issue is setting the volume on the unit to allow the remote to have "room" to be adjusteed to higher volume levels. The master volume on the unit limits the level. If powered off by remote, it must be powered up with the remote. I plan to buy many more.
Date published: 2014-04-19
Rated 5 out of 5 by from Great small amp; lots of features.Nice power, great features, easy to hook up. Small & simple remote.
Date published: 2014-03-14
Rated 5 out of 5 by from Great little Amp with many play back featuresThis amp has provided my R&D project to reach higher levels of achievement. Despite the power output is only 15W per channel the audio is clear and with proper tuning provides an all around solid sound. I was certainly surprised from it's performance considering it's a digital amp.I am operating Dayton Audio's, Audio exciters (Dayton Audio DAEX58FP) with this amp and it has met my expectations with continuing my project with this amp. The amp also has stellar audio play back options either from a standard SD card or a USB stick. It also has RCA inputs, which I haven't tried yet. This gives a simple way of providing extra options in on the go music capability. The FM radio tuning needs work, but I am not using it for FM reception or audio so I can't comment fully on that.The buttons feel good and are not loose as they seem to look cheap in the picture. The nobs are smooth and give good resolution in tuning. They don't feel loose or sloppy compared to the price. I was pleasantly surprised in the quality of the face of this amp. For a low budget amp it is defiantly worth the money for the use with memory type of music. The operations manual is completely written in Chinese and useless for anything that would require learning. As the front buttons are pretty much self explanatory so the manual isn't really needed.My use of the amp has been extensive since I received it. Playing music at full volume for 6 hours gives a slight raise in housing temperature, but not hot. Which tells me that it is efficient in heat dissipation and cooling. It even comes with an IR remote that works even at 25 feet. I can't complain about that.This amp will be my choice for my production project to come in the next few months. Thanks PE for distributing this great product.
Date published: 2013-10-01
Can you charge a smart phone using the usb? Thank you
Asked by:
The USB input on this amplifier will only accept flash cards, it will not charge a mobile device.
Date published: 2014-09-11
just received my Lepai A6USB/FM amplifier without any manual - bought this to use in my 1957 Ford (radio does not work but has power to it). Car is a 12V system, so I want to hook it up to the car power and use the SD or USB to play my 1950's song. Help
Asked by: rancher57
Date published: 2014-08-12
Hi, I have a Van and will like to know if I can connect any of this amp to my car.
Asked by: Jayman
Any amp that can be powered via 12 VDC can be used in a vehicle.
Date published: 2014-07-15
Would it hurt the amp to wire two 8 ohm speakers into a 4 ohm load (Dayton 2-1/2" full range) to run off one channel while running a single 4 ohm speaker (Dayton 4" mid woofer) off the other channel?
Asked by: wesleywells1
It will not hurt the amplifier, no.
Answered by: Eric Chandler
Date published: 2014-06-03
Can you safely tie the two "-" output lines together and run the output 3 wire (L, R, common)?
Asked by: MJB from KoP
Yes, the common is the same
Answered by: Nitnub
Date published: 2013-09-06
Does this amplifier have line out?
Asked by: JonC
No, this amp has many features, including several inputs. There are,however, only one pair of outputs and those are 4-8ohm speaker jacks.I assume you want to use this unit as a head unit and plug it into another amp or sound system. There used to be an adapter for car stereo output to line impedance to allow connection to an amp, but a very quick search online came up empty. There also used to be amps that input speaker level signals and boosted the wattage. I don't know if that would do what you need. Personally, I think you'd be better looking for a different unit. I do have a friend that used a car head unit with similar features and hooked it to his home amp. I would not call the results audiophile quality but it did sound good.
Answered by: TSiler
Date published: 2013-07-02
Customer projects that include: Lepai LP-A68 Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM
