310-301_ALT_0
Lepai LP-2020A+ Tripath Class-T Hi-Fi Audio Mini Amplifier without Power Supply
Brand:| Model: LP-2020A+
This Parts Express Lepai Tripath-based Class-T mini audio amplifier's small size and clean 20 watt output make it perfect for almost any auto or home audio project or DIY application where space is limited. Power supply not included.
  • Tripath TA2020 amplifier chip provides efficient, powerful sound
  • Economical price and tremendous performer
  • Compact size makes this amplifier great for projects and DIY audio applications
  • Aluminum enclosure that is lightweight, yet sturdy, and acts as a heat sink
  • 3.5 mm jack allows for easy connection to iPods, cell phones, and all sorts of MP3 players
310-301
Weight: 0.75 lbs.
OUT OF STOCK
Due In: 6/11/2015
List Price$29.99
You Save13%
$25.98
Buy 2-11 $22.50
Buy 12-up$19.80
Part # 310-301
This special purchase Lepai Tripath-based mini audio amplifier is ideal for both home and car audio applications. The amplifier's TA-2020 amp chip is a 20W/ch continuous average two-channel Class-T Digital Audio Power Amplifier IC that incorporates Tripath's proprietary Digital Power Processing™ technology. Class-T amplifiers offer the audio fidelity of Class-AB amps combined with the power efficiency of Class-D amplifiers. The Lepai amp's clean, 20 watt output makes it perfect for most any auto or home audio project or DIY application.
Google "Lepai LP-2020A+" and you'll find this little amp has been discussed and raved about! Each unit has an RCA Left and Right channel input, or you can use the 3.5 mm stereo input jack for plugging in almost any music source, such as iPods, cell phones, or MP3 players. Convenient spring terminals make connections to your speakers quick and easy! The Lepai mini amplifier has an aluminum enclosure that is lightweight, yet sturdy, and acts as a heat sink to keep the amp running cool. Color may vary.
Specifications: • Power output: 2 x 20 watts RMS • Input impedance: 47k ohms • Frequency response: 20 Hz - 20 kHz • Input sensitivity: 200 mV • Minimum THD: <0.05% • Required power supply (not included): 12 VDC 2A (2.5 mm x 5.5 mm plug, center positive) • Dimensions (D x W x H): 120 x 147 x 42 mm.
  • Special FeaturesClass T
  • BrandLepai
  • ModelLP-2020A+
  • Part Number310-301
  • UPC848864000770
  • Product CategoryHome Audio Amplifiers
    (15 Reviews)
  • Weight0.75 lbs.
View similar products to the Lepai LP-2020A+ Tripath Class-T Hi-Fi Audio Mini Amplifier without Power Supply
in the Home Audio Amplifiers product category.
Lepai LP-2020A+ Tripath Class-T Hi-Fi Audio Mini Amplifier without Power Supply is rated 4.4 out of 5 by 15.
Rated 4 out of 5 by from Does what it does.I bought this little amp so I could use a pair of Radio Shack Optimus 5 bookshelf speakers for my computer. I've been running it for about 6 months now. It works great. The sound is great with good definition of high bitrate MP3s.
Date published: 2015-01-29
Rated 5 out of 5 by from ImpressiveBought this amp for basically no reason, I had no idea what I would use it for - I just wanted see how it would sound.Purchased it as a combo with Dayton Audio B652 6-1/2" bookshelf speakers.Sound is crisp and distortion free up until just under half volume - which is pretty freaking loud for my application as desktop speakers. Prolonged listing from ~3' at half volume level would surely result in hearing damage. My amp came with a 12v dc @2amp power supply, I was reading somewhere that the new ones are shipping with a 3amp PSU - which might allow for higher volume levels without distortion. Added 2x 8" powered subwoofers for sub bass range - however, the Dayton Audio B652 paired with this amp hits a fantastic range I would guess as low as 40hz range.Anyhow, would I buy this product again? Yes!I plan on buying more for other projects.In closing: I am not saying this is the best amp available - I am saying this is the best amp you can buy for 26 bucks.
Date published: 2014-11-17
Rated 5 out of 5 by from More than I hoped for.I am an audiophile who fell on hard times and then my amp blew. I had $25 to spend and decided on this little beauty. I'm running a pair of hand built TMM 5" speakers that are about mid efficiency (85-87db, hard to say as the drivers were hand made). This little amp pushes them just fine. Can I shake the windows without distortion? Not anymore, but what do you expect for $20. My speakers are built to have super controlled bass rather than lots of it so I can hear a "muddiness" in the lows but, again, $20. On the down side I think the glowing volume knob is trashy and I would have paid another $2 for a headphone jack. This company makes an $11 version that I plan to incorporate into some computer speakers. Looking forward to see what $11 sounds like.
Date published: 2014-07-02
Rated 3 out of 5 by from If you need some tiny speakers, this is an amp.I just got the Lepai LP-2020A+ to boost the sound from my iPhone into some speakers mounted in the headrest of my recliner. As long as you don't turn up the volume on some combination of the source or the amp too much, it works. Crank it too much and the sound cuts out. Can't get excited about the performance. It's a 20 watt amp. Perhaps I need better speakers, or as another poster suggested, a better power supply.A real improvement would be more universal connections. The outputs are the type that clamp down on bare wire. (Whatever that's called) Who wants to strip wire, or depend on stripped wires? A 3.5mm output, like the input, would be perfect. Even RCA outputs would be a huge improvement. An even better improvement would be to have those connections on the front of the body.Anyway, it works. Far from perfect, but it works.
Date published: 2014-05-07
Rated 5 out of 5 by from Nice AmpI put this amp in an ammo can mp3 dock project. Works great, no problems.
Date published: 2014-03-28
Rated 5 out of 5 by from Great productMy intention was to get better sound when listening to music on my pc.After listening to several computer speakers I just couldn't find any that impressed me so I decided to put together my own system. I followed the advise of another reviewer and bought this amp and the 12v 5a power supply separately. I paired this set up with a pair of Dayton Audio B652's and I am blown away.....
Date published: 2014-02-24
  • 2015-03-02T06:34CST
  • co_hasreviews, tv_0, tr_15
  • loc_en_US, sid_310-301, PRD, sort_mostRecent
What is the maximum voltage of the adapter for your Lepai LP-2020A+
Asked by: roma19672
The recommended input power for this amp is 10-14.4VDC.
Date published: 2015-01-14
I've hooked the amp up to a wi-fi router and plan to leave it turned on. How man watts will it draw when not in use?
Asked by: nsmart
While I don't have an exact figure for you, this amplifier will draw less power than a normal clock radio when in standby mode.
Date published: 2014-12-31
This just arrived today, and played nicely for ten minutes. But then it started just blinking steadily with no output. The weird thing is the green light on the power supply is pulsing too at the same time. Even if nothing plugged in, blinks…. What to do?
Asked by: natevw
Can this be connected to the zone 2 "pre-out" on my receiver?
Asked by: bill23
Yes as long as it is a line level output.
Date published: 2014-12-18
Can both speaker output be wired together and if so what ohms for one speaker
Asked by: Ab2364
No the outputs cannot be wired together, this amp can only be used in stereo mode.
Date published: 2014-12-10
I am running:  2 x Dayton Audio RS52AN-8 2" Dome Midrange 2 x Dayton Audio DA175-8 7" Aluminum Cone Woofer 1 x Goldwood GT-302/S 1/2" Mylar Dome Tweeter Shielded Is the Lepai 2020+ a well suited amp for these speakers? Or need +power?
Asked by: Big_Al
This will power a pair of those without a problem, but whether you will need more power is determined by how loud you want them to play. At low levels you shouldn't need more power, but if you ever want to turn them up a bit we would recommend more power.
Date published: 2014-11-03
  • 2015-03-01T07:52CST
  • co_hasquestionsanswers, tq_23
  • loc_en_US, sid_310-301, PRD, sort_recentQuestionsFirst
Customer projects that include: Lepai LP-2020A+ Tripath Class-T Hi-Fi Audio Mini Amplifier without Power Supply
