310-302_ALT_0
310-302_ALT_1
310-302_ALT_2
Lepai Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM
Brand:| Model: LP-A68
Up to 15 watts of stereo power are on tap with the Lepai LP-A68. Additionally you will find included features such as: built-in FM tuner with collapsible antenna, MP3 decoding with USB and SD/MMC input, IR remote control, four EQ functions, and tone controls. Power supply included.
  • All-in-one amplifier with SD/MMC card and USB input
  • Up to 2 x 15W of output
  • Power supply, IR remote, and FM antenna included
  • 4-ohm stable
  • 12 VDC power supply included
310-302
Weight: 1 lbs.
OUT OF STOCK
Due In: 4/24/2014
List Price$39.99
You Save34%
$26.00
Buy 4-up$24.80
Part # 310-302
The Lepai LP-A68 combines an FM tuner, MP3 playback with SD/MMC card and USB support, and an IR remote control together with a minimum footprint stereo amplifier that can be used virtually anywhere!
Front mounted treble, bass, and volume controls, as well as a four function EQ with pop, jazz, classic, and rock settings (accessible via the remote control), allow you to dial in the sound to match your taste and get the most out of your speakers. A 12 VDC power supply is included, and a 9-1/2" long collapsible FM antenna is built-in, as are a set of stereo RCA inputs and a stereo 3.5 mm stereo input.
Specifications: • 2 x 15W RMS • Power requirements: 12 VDC • DC power input jack: 2.1 mm x 5.5 mm • Stable down to 4 ohms • Minimum THD: <1% • Signal-to-noise ratio: >80 dB • Frequency response: 20-20,000 Hz • Input impedance: 47k ohms • FM tuner frequencies: 87.5 to 108 MHz • FM receiver sensitivity: 16 dB • FM signal-to-noise ratio: 60 dB • Channel separation: 39 dB • Dimensions (including mounting flange): 6" W x 2-3/4" x 1-5/8" H.
  • Power Output (RMS Per Channel @ 8 ohms)15 Watts
  • Power (RMS/Channel 8 ohms)0 - 25 Watts
  • Special FeaturesFM Tuner,USB Connectivity,SD Card Input,Remote Control
  • Weight Range< 10 lbs.
  • BrandLepai
  • ModelLP-A68
  • Part Number310-302
  • UPC844632089404
  • Product CategoryAmplifiers
    (35 Reviews)
  • Weight1 lbs.
View similar products to the Lepai Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM
in the Amplifiers product category.
Lepai Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM is rated 3.9143 out of 5 by 35.
Rated 5 out of 5 by from Great small amp; lots of features.Nice power, great features, easy to hook up. Small & simple remote.
Date published: 2014-03-18
Rated 5 out of 5 by from Great little Amp with many play back featuresThis amp has provided my R&D project to reach higher levels of achievement. Despite the power output is only 15W per channel the audio is clear and with proper tuning provides an all around solid sound. I was certainly surprised from it's performance considering it's a digital amp.I am operating Dayton Audio's, Audio exciters (Dayton Audio DAEX58FP) with this amp and it has met my expectations with continuing my project with this amp. The amp also has stellar audio play back options either from a standard SD card or a USB stick. It also has RCA inputs, which I haven't tried yet. This gives a simple way of providing extra options in on the go music capability. The FM radio tuning needs work, but I am not using it for FM reception or audio so I can't comment fully on that.The buttons feel good and are not loose as they seem to look cheap in the picture. The nobs are smooth and give good resolution in tuning. They don't feel loose or sloppy compared to the price. I was pleasantly surprised in the quality of the face of this amp. For a low budget amp it is defiantly worth the money for the use with memory type of music. The operations manual is completely written in Chinese and useless for anything that would require learning. As the front buttons are pretty much self explanatory so the manual isn't really needed.My use of the amp has been extensive since I received it. Playing music at full volume for 6 hours gives a slight raise in housing temperature, but not hot. Which tells me that it is efficient in heat dissipation and cooling. It even comes with an IR remote that works even at 25 feet. I can't complain about that.This amp will be my choice for my production project to come in the next few months. Thanks PE for distributing this great product.
Date published: 2013-10-01
Rated 4 out of 5 by from The 21st Century Integrated AmpAs technology evolves, we lump features together, trying out various combinations in the eternal search for the best balance between value, flexibility, reliability and ease of use. This inexpensive and innovative unit yields tremendous bang for tiny bucks. By adding a cigarette-lighter power adapter, a couple of Outdoor-proof speakers and some zip cord, I quickly and inexpensively had a very flexible and usable music system for camping.I would like to have seen a pair of ΒΌ" TS jacks for the speakers, and an up-rated unit would have an LCD to identify the input in-use and to show what track is being played from the USB, but this thing is amazing for the price.
Date published: 2013-09-17
Rated 4 out of 5 by from Nice Little AmpI bought this amp to build a powered monitor in a 40mm ammo box. It works quite nicely. The input sensitivity is slightly lower than expected, so if you are going to drive it from the headphone output of an iTouch/iPhone/IPad and want to drive it to full volume, you will need a preamp to boost the signal. The FM tuner is a nice surprise if you don't mind guessing what station you're listening to. Otherwise it's a nice small device that does the job. BTW, the outputs are not bridgeable, and you cannot wire the "-" sides together and run three wire L-Common-R.
Rated 5 out of 5 by from Definitely Hard to Beat for the PriceI have two of these and I'm 99% happy with them both. One is mounted on the crossbar of my Buell, the other is attached to a couple gator clamps so I can mount it in my canoe. On my Buell, I had to use filters to keep ignition noise from the unit and I also had to learn to turn them on before I put my helmet on as there is a seriously nasty, ear-breaking "pop" when the unit is turned on. In the canoe, they power a pair of 6" car speakers. There's never as much bass as I would like, but for the money, I can't seriously complain. Also, at $26 a pop, I'm not going to feel bad if either unit gets wet due to rain or paddle splash and gets ruined. I exclusively use the SD memory card input - the USB probably works, but I prefer the smaller SD cards. Most places I ride or paddle are not conducive to FM, so I've never really tested the radio feature.
Date published: 2013-08-27
Rated 4 out of 5 by from Lepai 2x15W Amplifier on my DeckI'm using this amplifier on my deck to drive two JBL N24 speakers. My input source is an LED TV. I connected the headphone jack of the TV to the Amplifier using the mini plug. It takes some power to drive the JBL's (rated at 100 watts max). Well, this little amp is doing a great job. I have the amp turned to maximum volume. I use the TV remote control to increase the signal (volume) from the TV to the amp. I can go from normal listening level to loud with no distortion. When I try to go 'real loud', they start getting distorted. But, I only did that to test how loud it would go! My TV is a smart TV and I can listen to Pandora through the amp this way. It sounds great. I have not tried the other features of the amp but it works great for this purpose.
Date published: 2013-08-21
power supply voltage?
Would a regulated 15V DC power supply be too much to power this amp safely?
Asked by: rodavis2
Since it comes with a 12V power supply, I would use that. The internal ICs, electrolytic capacitors, and transistors may or may not withstand 15V. To me it seems an unnecessary risk to try a higher voltage supply.
Answered by: Audio Nut
Date published: 2013-04-05
will ipod play
will only thumb drives play or can an ipod be attached
Asked by: jalng63
Almost certainly. These amps are designed to work with most MP3 players. I have no direct experience with this particular product, but others have reported success.
Answered by: Doc Jones
Date published: 2012-02-26
Is the remote line-of-sight only or will it work "through" objects?
Asked by: Moto tech guy
ir is line of sight
Answered by: digitalhaven 53
Date published: 2012-03-19
Is there a display that shows the FM station?
Asked by: Grrr
Nope. Just scan buttons to find stations. Reception is decent, but not spectacular.
Answered by: Lafcadio
Date published: 2012-03-07
Wher can I find the remote code for this?
Asked by: mobrit
Excellent question:The codes these remotes use may be unpublished or even proprietary.If you want to use a programmable remote you might have to resort to the "learn" mode. This won't take long since there are few functions to teach.
Answered by: Fanden
Date published: 2013-10-27
Is it possible to use an antenna other than the extendable one shown on the picture
Several commenters have noted poor reception. Is it possible to attach a remote antenna (one on the roof of a garage, for example) to this unit?
Asked by: JPMC
It should be possible, but it would probably include opening the box to solder the other antennas cable to where the default one is connecter, thus invalidating the warranty.
Answered by: Domingos
Date published: 2012-04-11
Customer projects that include: Lepai Digital 2x15W Mini Amplifier with Remote USB MP3 Media Card FM
