073-062_ALT_0
LED Heatsink for 20-50W High Power LEDs
Brand:| Model: DC-HS11116
This heatsink offers protection from high temperatures for your high power 20W, 30W, or 50W LED.
  • Extruded aluminum heatsink for high output LEDs
  • Designed for mounting one 20W, 30W, or 50W high power LED
  • Mounting screws included
073-062
Weight: 0.3125 lbs.
IN STOCK
List Price$9.99
You Save51%
$4.93
Buy 4-up$4.68
Part # 073-062
Protect you high output LEDs from overheating with this extruded aluminum heatsink. 3 mm pre-drilled holes offers easy mounting of one 20W, 30W, or 50W high power LED. Includes four 3 mm screws. LED mounting (top base) dimensions: 1.95" W x 2.36" L (49.5 x 60 mm). Bottom base dimensions: 1.94" W x 3.125" L (49.2 x 79.4 mm). Overall height: 2" (50.8 mm).
Note: In some applications, a cooling fan may be needed in addition to this heatsink.
  • BrandParts Express
  • ModelDC-HS11116
  • Part Number073-062
  • UPC844632093654
  • Product CategoryHigh-Power LED Assemblies
    (2 Reviews)
  • Weight0.3125 lbs.
View similar products to the LED Heatsink for 20-50W High Power LEDs
in the High-Power LED Assemblies product category.
LED Heatsink for 20-50W High Power LEDs is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from Good service, but not enough sink for 50W LEDBought three. Service was fast. Looks like a large enough heat sink for 30W or so. 50W cool white LED cycles even at 60F ambient temp. Feels warm enough to blister my skin.
Date published: 2014-10-31
Rated 5 out of 5 by from affordable & usefulThis worked fine, am completely satisfied.I used it on a tk2050 Tripath amplifier - so it's not what it's intended for but works well for other things than LEDs too.I needed a heatsink that would provide a horizontal surface, so that I could add coolers if needed. The stock heatsink just wasn't cooling enough and had vertical fins, couldn't add heatsinks easily, wasn't any room to. Plus many others only also had vertical fins too.Anyhow this worked perfectly, draws off tons of heat, and easily bolt-attached to the outer case (or other heatsinks can easily bolt on top of it) so it now keeps my amp supercool.Great quick fix for cheap.
Date published: 2013-08-14
  • 2015-04-19T09:16CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_073-062, PRD, sort_mostRecent
Customer projects that include: LED Heatsink for 20-50W High Power LEDs
