SALE
073-086_ALT_0
073-086_ALT_1
073-086_ALT_2
073-086_ALT_3
073-086_ALT_4
073-086_ALT_5
073-086_ALT_6
073-086_ALT_7
073-086_ALT_9
Lavolta SMD5050 RGB Waterproof 300 LED 16 ft. Tape Light Strip with 12 VDC 6A Power Supply & Mini 44-Key Remote
Brand:|Model: KIT-1|Part # 073-086
Lavolta packages everything you need to create your own custom LED display together in this kit. Stick it on, plug it in, and light it up using the remote to customize your lighting for any occasion.
List Price$69.99
Regular Price$34.80
You Save26%
Sale Price
$25.88
Part # 073-086
  • 300 IP65 rated LEDs with many different color combinations
  • Includes 44-key controller with DIY keys for endless custom colors
  • Packaged with a 12V, 6A power supply for maximum brightness
  • Impact resistant and weatherproof for outdoor use with 3M adhesive backing
The Lavolta KIT-1 is easy to set up and operate, yet highly customizable. Installation is quick and simple using the 3M adhesive backing on the LED strip. Cut the LEDs to a specific length with copper pads placed every 2". These pads also make it simple to make 90° turns or add extensions. This kit is the ideal product for turning any room, shelving unit, or patio into a unique lighting experience.
Each SMD5050 LED is CE and RoHS compliant, the entire strip is IP65 rated (no ingress of dust; complete protection against contact. Water projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects).
You can really get the show going with the included 44-key IR remote that gives you options ranging from slow pulsing fades, to incredibly quick color changes, and every mood from sedate to energetic. The Lavolta KIT-1 is perfect for holiday decorating, parties, or to add architectural lighting flair to homes and offices.
A switching 12 VDC, 6A power supply (with 8 feet of cable) is included for maximum LED brightness.
Note:Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth. In order to connect the LED lighting strip correctly to the remote control, align the black wire with the controller connector's arrow. The strip will only work in one direction, and you cannot harm the strip by connecting it backwards. Install the LED strip connector to the controller connector with both arrows in alignment.
To use the DIY memory keys, press the desired memory key, use the up/down red, green, or blue arrows to adjust to desired color, then press the DIY memory key again to store the color.
Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings.
Strip Specifications: • Overall dimensions: 0.44" W x 196.80" L x 0.125" H (11 x 5000 x 3.2 mm) • Segment dimensions (98 segments per strip): 2" (50.8 mm) L. • Current draw: 2A.
RGB LED Specifications: • LED type: SMD 5050 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
IR Remote Specifications:• Output: Three CMOS drain-open output • Connection type: Common anode • Control unit dimensions: 63 mm (2.48") L x 35 mm (1.38") W x 22 mm (0.87") H.
Power Supply Specifications: • Input: 100V to 240 VAC 50/60 Hz, 1.6A • Output: 12V, 6A • Power brick dimensions: 4-7/8" L x 2-1/8" W x 1-1/4" H • Total cord length: 96".
Remote control button layout
Brightness + (7 steps)Brightness - (7 steps)Pause/RunOn/Off
Static redStatic greenStatic blueStatic white
Static orangeStatic pea greenStatic dark blueStatic off-white
Static dark yellowStatic cyanStatic royal blueStatic light pink
Static yellowStatic light blueStatic pinkStatic green white
Static light yellowStatic sky blueStatic brownStatic blue white
Increase redIncrease greenIncrease blueSpeed up
Decrease redDecrease greenDecrease blueSpeed down
Memory 1Memory 2Memory 3Automatic change
Memory 4Memory 5Memory 6Flash on and off
3 color change7 color change3 color fade change7 color fade change
  • BrandLavolta
  • ModelKIT-1
  • Part Number073-086
  • UPC848864006154
  • Product CategoryAccent & Party Lighting
    (54 Reviews)
  • Weight1.55 lbs.
View similar products to the Lavolta SMD5050 RGB Waterproof 300 LED 16 ft. Tape Light Strip with 12 VDC 6A Power Supply & Mini 44-Key Remote
in the Accent & Party Lighting product category.
