RGB 300 LED SMD 5050 5m Tape Strip 12 VDC Waterproof IP65
073-076_ALT_0
073-076_ALT_1
073-076_ALT_2
073-076_ALT_3
073-076_ALT_4
073-076_ALT_5
073-076_ALT_6
073-076_ALT_7
073-076_ALT_8
Lavolta RGB 300 SMD5050 LED 16 ft. Tape Lighting Strip 12 VDC Waterproof IP65 for Standalone or Add-On Strip to Lavolta KIT-1
Brand:|Model: LEDS-16|Part # 073-076
Add excitement and powerful effects lighting to your DJ, bar, bedroom, den, kitchen, patio, or any other area you can think of! It's easy to add that soft ambient mood setting glow to your living space or create powerful, bright, pulsating, LED effects! Perfect for creating your own custom lighting with RGB LED tape strips or as an add-on strip to an existing LED lighting installation. Perfect choice for extending the LED strip length of the Lavolta KIT-1 (#073-086). Pre-applied adhesive attaches to almost any surface and the sealed design is impact resistant and weatherproof.
List Price$79.99
You Save75%
$19.90
Buy 4-11 $19.50
Buy 12+$18.80
Part # 073-076
  • 300 LEDs with millions of different color combinations
  • Perfect add-on strip for Lavolta KIT-1 (#073-086)
  • Longer life and lower power consumption compared to rope lights
  • Great for use as holiday lighting, indoor accent lighting... even in automotive applications!
  • Connects to LED remote control units for custom effects
  • Cut lines on circuit board for creating miniature segments
  • Impact resistant and weatherproof for outdoor use with 3M adhesive backing
RGB LED tape strips are built with 3 bright surface mount RGB LEDs per every 2" for the best possible color density. These Lavolta LED strips are great for use as indoor strip lighting or illuminating a display case. Connecting multiple strips together is made quick and simple with solder tabs on the end of each strip. Aggressive adhesive is affixed to the back of the strip for permanent mounting. 10 miniature flexible mounting brackets with 20 mounting screws are included for additional support.
Each Lavolta LED strip is marked with cut lines for creating a custom length strip, or up to 98 miniature 2" strip segments with three RGB LEDs per section. Each section features four solder points (voltage +, green, red, and blue) to create one of seven different colors and for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in. Simply connect a 12 VDC power supply (up to a 12 VDC, 6A power supply is recommended and sold separately) to the solder points (see wiring diagram in Manuals/Resources section on the right) and go! Additionally, you can use either the 24 or 44-key remote control LED control unit for color control or to create amazing effects. Pre-terminated with a 5" pigtail for connection to an LED control unit (sold separately). CE and RoHS compliant, IP65 rated (no ingress of dust; complete protection against contact. Water projected by a nozzle (6.3 mm) against enclosure from any direction shall cause no harm.)
Power supply sold separately, please refer to the Related Items section.
Note: Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth. In order to connect the LED lighting strip correctly to a 24 or 44-key controller, align the black wire with the controller connector's arrow. The strip will only work in one direction, and you cannot harm the strip by connecting it backwards. Due to the IR operation of this product, it is possible for remote controls of other devices to inadvertently change LED settings. Connecting more than two 16 ft. strips together is not recommended. For runs longer than 32 ft., it is recommended that each strip be wired directly to the power supply.
Strip Specifications: • Minimum power requirements (per strip): 12 VDC, 2A • Overall dimensions: 0.44" W x 196.80" L x 0.125" H (11 x 5000 x 3.2 mm) • Segment dimensions (98 segments per strip): 2" (50.8 mm) L.
RGB LED Specifications: • LED type: SMD 5050 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
  • BrandLavolta
  • ModelLEDS-16
  • Part Number073-076
  • UPC844632093722
  • Product CategoryAccent & Party Lighting
    (28 Reviews)
  • Weight0.6 lbs.
View similar products to the Lavolta RGB 300 SMD5050 LED 16 ft. Tape Lighting Strip 12 VDC Waterproof IP65 for Standalone or Add-On Strip to Lavolta KIT-1
in the Accent & Party Lighting product category.
Videos
