Lavolta LED Lighting Strip Dual Splice Cable 150mm 5 Pcs.
Brand:|Part # 073-0108
This Lavolta 150 mm (5.91") LED lighting strip extension cable includes two LED segment splices for making your own custom length. Great for routing against complex angle surfaces.
List Price$8.99
You Save34%
$5.94
Buy 10-49 $5.44
Buy 50+$4.93
Part # 073-0108
  • Provides a solder-free 5.91" long extension for indoor, non IP65-rated LED lighting strips
  • With the use of solder, provides quick strip segment connection for IP65-rated LED lighting strips
  • Creates a really thin power connection for difficult mounting locations
  • Sold in bags of 5
Use this 5.91" (150 mm) LED lighting strip extension cable with two LED segment splices, from Lavolta, for making your own custom length LED lighting strip. Route your lighting strip segments around corners, under door gaps, and in minimum clearance areas due to the connection cable's 1.5 mm high by 6 mm wide size. Originally designed for use with indoor RGB LED strip lighting (without the IP65 resin drip coating) for a solder-free connection, this splice can be used with flexible IP65-rated LED strip lighting with the use of solder. A clam-shell cover provides protection against accidental shorting. Sold in bags of 5.
Instructions for use with coated, IP65-rated RGB LED strips:
1) Remove about 1/4" of the resin drip coating from the end that is to be inserted into the splice, exposing the four solder pads
2) Place a very small amount of solder on each pad (just enough to color the pad silver, 0.031" thickness solder is recommended)
3) Insert the exposed portion of the strip into the splice, two retaining clips holds the strip in place
4) Heat tabs directly over the solder pads while pressing down
5) Close clamshell cover, repeat steps with opposite side, cover and seal with heat shrink (18 mm heat shrink with adhesive is recommended)
Note: When directly connecting multiple LED strips together using this 4-pin male-to-male connector, it is important not to exceed a total series length of 33 feet. Doing so can damage some controllers, power supplies, and cause resistors within the LED lighting strip to overheat, creating a color difference between strips.
  • BrandLavolta
  • Part Number073-0108
  • UPC848864015538
  • Product CategoryLED Strip Lighting & Controllers
    (1 Reviews)
  • Weight0.0500 lbs.
Lavolta LED Lighting Strip Dual Splice Cable 150mm 5 Pcs. is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from Out-of-Plane CornersI am using this splice to turn a 90 degree corner where the two connected lighting strips are not in the same plane. After examining the product and its flexibility, it should work. Will have to staple the cable leads to get it to lay flat and out of sight.
Date published: 2014-08-04
  • 2016-02-09T06:46CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-0108, PRD, sort_mostRecent
can i put those 2 in a row i want a 300 mm splice so can i put those 150 mm behind eachother would that work or is that possible ? pls answer on remcovissers29@gmail.com thank u for ur time
Asked by: Remco
  • 2016-01-21T07:25CST
  • co_hasquestions, tq_1
  • loc_en_US, sid_073-0108, PRD, sort_recentQuestionsFirst
