073-0106_ALT_1
Lavolta LED Lighting Strip Connection Cable Female to Splice 200mm 5 Pcs.
Brand:|Part # 073-0106
This 6" LED lighting strip female extension cable with splice, from Lavolta, provides quick segment connection. Works with non IP65-rated LED lighting strips without solder, and also with IP65-rated LED lighting strips with the use of solder.
List Price$7.99
You Save31%
$5.52
Buy 10-49 $4.87
Buy 50+$4.22
Part # 073-0106
  • Provides a solder-free connection for indoor, non IP65-rated LED lighting strips
  • With the use of solder, provides quick strip segment connection for IP65-rated LED lighting strips
  • Connect an LED segment to another LED lighting strip or to an LED controller
  • Sold in bags of 5
Use this Lavolta 152 mm (6") LED lighting strip female extension with splice to make connecting LED lighting strip segments together easy. Originally designed for use with indoor RGB LED strip lighting (without the IP65 resin drip coating) for a solder-free connection, this splice can be used with flexible IP65-rated LED strip lighting with the use of solder. A clam-shell cover provides protection against accidental shorting. The female side is used to connect to either another LED lighting strip segment or to an LED controller. Dimensions: 15 mm W x 16 mm L x 5 mm H. Sold in bags of 10.
Instructions for use with coated, IP65-rated RGB LED strips:
1) Remove about 1/4" of the resin drip coating from the end that is to be inserted into the splice, exposing the four solder pads
2) Place a very small amount of solder on each pad (just enough to color the pad silver, 0.031" thickness solder is recommended)
3) Insert the exposed portion of the strip into the splice, two retaining clips holds the strip in place
4) Heat tabs directly over the solder pads while pressing down
5) Close clamshell cover, cover, and seal with heat shrink (18 mm heat shrink with adhesive is recommended)
Note: When directly connecting multiple LED strips together using this 4-pin male-to-male connector, it is important not to exceed a total series length of 33 feet. Doing so can damage some controllers, power supplies, and cause resistors within the LED lighting strip to overheat, creating a color difference between strips.
  • BrandLavolta
  • Part Number073-0106
  • UPC848864015552
  • Product CategoryLED Strip Lighting & Controllers
    (1 Reviews)
  • Weight0.0500 lbs.
Lavolta LED Lighting Strip Connection Cable Female to Splice 200mm 5 Pcs. is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Strip Connection CableThis product works great! "plug and play" Connecting the strip connection cable to the LED lights was very simple and fast. It eliminates soldering!
Date published: 2014-06-17
  • 2016-02-05T06:46CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-0106, PRD, sort_mostRecent
So you get 5 of these cables for that price or is that price per cable?
Asked by: Apache
That price is for 5 cables.
Date published: 2014-05-06
  • 2016-02-05T07:16CST
  • loc_en_US, sid_073-0106, PRD, sort_recentQuestionsFirst
