SALE
073-088_ALT_0
073-088_ALT_1
073-088_ALT_2
073-088_ALT_3
073-088_ALT_4
073-088_ALT_5
073-088_ALT_10
073-088_ALT_11
073-088_ALT_12
073-088_ALT_6
073-088_ALT_7
073-088_ALT_9
Lavolta KIT2 300 LED 16 ft. Tape Lighting Strip 12 VDC Waterproof IP65 Music Control 6A PSU
Brand:|Model: KIT2|Part # 073-088
The KIT2 by Lavolta includes a 16 ft. RGB LED strip and variable music controller. Everything you need to get the party started!
List Price$79.99
Regular Price$44.80
You Save11%
Sale Price
$39.80
Part # 073-088
  • 300 red, green, and blue surface mount LEDs on a single strip
  • Flexible IP65 waterproof coating
  • Variable control unit that responds to live music
  • Unlimited placement options with aggressive adhesive backing
The Lavolta KIT2 is easy to set up and operate, yet highly customizable. Installation is quick and simple using the 3M adhesive backing on the LED strip. Cut the LEDs to a specific length with copper pads placed every 2". These pads also make it simple to make 90 degree turns or add extensions. This kit is the ideal product for turning any room, shelving unit, or patio into a unique lighting experience.
Each RGB SMD5050 LED is CE and RoHS compliant, the entire strip is IP65 rated (no ingress of dust; complete protection against contact. Water projected by a nozzle (6.3mm) against enclosure from any direction shall have no harmful effects).
The included control unit has multiple functions to light up any occasion. The "Music 1" setting keeps the lights on constantly while changing colors to the beat of music via microphone. The "Music 2" function strobes various colors to the beat of the music. Dial on the side adjusts sensitivity for both music settings depending on how much light change you want. The "Single Color" setting lets you toggle through 6 different colors to stay on constantly. Finally the "RGB" setting will fade from off to each of the 3 colors, continuously.
Note: Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth. In order to connect the LED lighting strip correctly to the remote control, align the black wire with the controller connector's arrow. The strip will only work in one direction, and you cannot harm the strip by connecting it backwards. Install the LED strip connector to the controller connector with both arrows in alignment.
Strip Specifications: • Overall dimensions: 0.44" W x 196.80" L x 0.125" H (11 x 5000 x 3.2 mm) • Segment dimensions (98 segments per strip): 2" (50.8 mm) L.
LED Specifications: • LED type: SMD 5050 • Red: 624 nm wavelength, 18 lumens • Green: 518 nm wavelength, 45 lumens • Blue: 471 nm wavelength, 18 lumens.
Control unit dimensions: • 2-5/16" L x 3-1/2" W x 1" H.
Power Supply Specifications: • Input: 100V to 240 VAC 50/60 Hz, 1.6A • Output: 12V, 6A • Power brick dimensions: 4-7/8" L x 2-1/8" W x 1-1/4" H • Total cord length: 96".
  • BrandLavolta
  • ModelKIT2
  • Part Number073-088
  • UPC848864012285
  • Product CategoryAccent & Party Lighting
    (10 Reviews)
  • Weight1.5 lbs.
View similar products to the Lavolta KIT2 300 LED 16 ft. Tape Lighting Strip 12 VDC Waterproof IP65 Music Control 6A PSU
in the Accent & Party Lighting product category.
