246-453_ALT_0
246-453_ALT_1
KRK VXT4-NA 4" 2-Way Active Studio Monitor 45W Bi-Amp Each
Brand:| Model: VXT-4
The KRK VXT4 monitor is a visually striking design that is equally functional. The sleek curvature provides excellent imaging characteristics and a wider sweet spot, achieving a new level of precision.
  • ABS (Acrylonitrile Butadiene Styrene) foam enclosure
  • Front-firing radiused, non-parallel ports
  • Radiused enclosure edges
  • Proprietary woofer design
  • HF and LF controls
  • Multiple protection circuits
246-453
Weight: 16.2 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$499.00
You Save40%
$299.00
Part # 246-453
The VXT4 by KRK Systems features a silk dome tweeter for fast transient response and a new woofer design with a stiffer, lighter Kevlar cone that provides low distortion and extended low-end response. Both have vented formers to remove heat and reduce the effects of power compression, enabling the monitors to maintain their sonic signature even under the most demanding conditions.
This powered monitor system has tamper resistant switch covers and integrated omni-mount support. The VXT series is an outstanding choice for a broad range of monitoring applications.
Specifications: • Configuration: 2-way  • System type: Active studio monitor  • Low-frequency: 4" woven Kevlar woofer  • High-frequency: 1" silk dome tweeter • Frequency response: 66 Hz - 22 kHz  • Max SPL: 107 dB • Amplifier class: A-B • Power output: 45 watts • Input impedance: 10K ohms balanced • LED indicators: Power, clip, limit • Inputs: Balanced 1/4"/XLR combo • Power: Selectable 110V-120V / 220V-240V (50Hz - 60Hz) or 100V (50Hz - 60 Hz) • Dimensions: 10" H x 7.34" W x 7.48" D (254 x 186 x 190 mm) • Weight: 14 lbs. (6.36 kg).
  • Speaker TypeActive / Powered
  • Speaker Configuration2-Way
  • Woofer Size4"
  • BrandKRK Systems
  • ModelVXT-4
  • Part Number246-453
  • UPC816654000767
  • Product CategoryStudio Monitors
  • Weight16.2 lbs.
View similar products to the KRK VXT4-NA 4" 2-Way Active Studio Monitor 45W Bi-Amp Each
in the Studio Monitors product category.
Customer projects that include: KRK VXT4-NA 4" 2-Way Active Studio Monitor 45W Bi-Amp Each
