KRK Systems RP8G2 RoKit G2 8" 2-Way Active Near-field Studio Monitor
Brand:|Model: RP8G2|Part # 246-462
The KRK RP8G2 Rokit has all the components Rokits are known for but also with refined voicing and a new curved baffle that looks great, reduces diffraction and provides better monitoring accuracy.
Comparable Items In Stock:
Part # 246-462
  • 1" Neodymium soft dome tweeter with ferrofluid
  • 8" glass Aramid composite cone woofer
  • Radically curved front plate design virtually eliminates diffraction distortion
  • Waveguide design provides amazing detail and imaging
  • Front-firing port provides low freq extension without boundary coupling
  • New speaker voicing for even more accurate frequency response
  • MDF enclosure with black vinyl wrap
The KRK Rokit Series takes value-priced monitors to a new performance level. For years the Rokit series has been a popular choice for accurate monitoring in studios large and small. Now the all new Generation 2 RoKit provides a new standard for even better performance and accuracy, raising the bar once again.
    No Pain With Gain
    Why compromise gain structure to achieve a comfortable listening level? As musicians and recording people ourselves, they've asked that question too. So each Generation 2 Rokit comes with an Input Volume Control that provides an adjustable gain range from +6 dB to -30 dB. Just another way the Rokit lets you focus on your mix, and not on compatibility concerns.
    Catch A Wave, For A 3D Mix
    Recessed tweeters may look the same, but they don't perform the same. KRK has designed a superior tweeter wave guide for the Rokit that provides optimal high frequency pattern control and focuses the sound outward, away from the cabinet. More conventional designs direct sound along the plane of the cabinet where waveform interaction can cause phase problems and increased diffraction. KRK knows a properly engineered high frequency wave guide is a critical component to great sound, and one key to our award winning performance.
    You've Got Connections
    At KRK our focus is your mix. But it doesn't stop at creating accurate monitors. We live this stuff and appreciate the need for monitors that not only sound great but work easily into your particular set up. That's why you'll find plenty of input options with your Rokit, sure to accommodate any studio environment. So if it's RCA, Quarter-Inch (balanced/unbalanced) or XLR inputs you require, Rokit has got you covered.
    Even More Accurate Than Before
    KRK took a great monitor series and made it better. Their engineers and listening panel took the Generation 2 Rokits' speaker voicing to even more accurate levels. What you hear is what you are intended to hear, coloration is not part of the spec. This performance is brought to you by drivers that are custom-designed by our world-class studio monitor engineering team, for clear, low-distortion performance.
    Take Control
    While your Generation 2 Rokit leaves the factory voiced to our demanding specs, KRK also knows that no two rooms "sound" the same. As such, each Rokit comes equipped with a High Frequency Level Control. This feature provides specific adjustment of high frequency output most commonly affected by room acoustics. It's just one extra level of control that KRK gives you to ensure the most accurate mix for your particular room's acoustics.
    Don't Be Square, Curves Ahead
    KRK's new Rokit looks different, so it can sound better, and in a wider "sweet spot". Traditional rectangular speakers suffer from diffraction as sounds leaving the edge of the cabinet are reflected back into the original sound field, and at different time intervals. This phase distortion creates a "narrow" or boxy" sound. The Generation 2 Rokit series eliminates this issue with radically engineered curved surfaces, so diffraction is virtually eliminated. Simply put, you'll get better sound in a wider area.
    Let's Be Up Front
    Take a look at competitive monitors and you'll find ports on the back of the cabinet. These rear-firing ports tend create bass coupling with walls and corners amplifying low frequency information which will color your mix. The superior design of the KRK Generation 2 Rokit's include front-firing ports, which are just the right shape and taper to reduce port turbulence. You'll appreciate the clean and accurate bass performance, this approach delivers, even at high SPL's.
    Power Up!
    A great sounding monitor doesn't stop with a great cabinet and custom drivers. KRK's true bi-amplified amplifier system provides discrete low-distortion power for each driver. The active crossover systems provide smooth and accurate frequency response, and again, accurate diffraction control.
    Specifications: • Configuration: 2-way • System type: Active studio monitor • Low-frequency: 8" Aramid glass composite woofer • High-frequency: 1" silk dome tweeter • Frequency response: 44 Hz - 20 kHz  • Max SPL: 109 dB • Amplifier class: Class A-B • Power output: 20 watts HF;  70 watts LF • Input impedance: 10K ohms balanced • HF level adjust: -2 dB, -1 dB, 0, +1 dB • LF level adjust: N/A • Indicators: Power • Video shielding: Yes • Inputs: Balanced XLR (3-pin), balanced 1/4" TRS, unbalanced RCA • Power: Selectable 110~120V / 220~240V, 50~60 Hz • Dimensions: 15.5" H x 10.83" W x 11.73" D (394 x 275 x 289 mm) • Weight: 26 lbs. (12 kg).
    • Speaker TypeActive / Powered
    • Speaker Configuration2-Way
    • Woofer Size8"
    • BrandKRK Systems
    • ModelRP8G2
    • Part Number246-462
    • UPC816654001238
    • Product CategoryStudio Monitors
    • Weight30.1 lbs.
    View similar products to the KRK Systems RP8G2 RoKit G2 8" 2-Way Active Near-field Studio Monitor
    in the Studio Monitors product category.
