KRK RP10-3 RoKit 10" 3-Way Active Studio Monitor Each
Brand:|Model: RP10-3|Part # 246-463
The KRK RP10-3 powered monitors are sought after solutions for precision monitoring in studios around the world. The state of the art design provides unsurpassed power level, performance, and accuracy.
Part # 246-463
  • 1" soft dome tweeter
  • 10" aramid glass composite woofer
  • Radically curved front plate design virtually eliminates diffraction distortion
  • Waveguide design provides amazing detail and imaging
  • Front-firing slotted ports reduce port turbulence
The Rokit series by KRK gives professional and commercial facilities the ability to operate using one monitoring system. The powered RP10-3 delivers power, accuracy, and clarity that is demanded in environments which call for single monitoring systems.
This mid-field 3-way monitor system enclosed in a compact form factor suits commercial facilities in need of a compact mid-field solution as well as private or project studios wanting to step up to a new level of performance and value. All genres of music will benefit from the high SPL output which reproduces challenging highly dynamic tracks. Sold individually.
Specifications: • Configuration: 3-way • System type: Active studio monitor • Low-frequency: 10" aramid glass composite woofer • High-frequency: 1" soft dome tweeter • Frequency response: 31 Hz - 20 kHz  • Max SPL: 113 dB • Amplifier class: A-B • Power output: 140 watts • Input impedance: 10K ohms balanced • HF level adjust: -2 dB, -1 dB, 0, +1 dB • LED indicators: Power • Inputs: Balanced XLR, balanced 1/4" TRS, unbalanced RCA • Power: 120V, 60 Hz • Dimensions: 21.2" H x 12.7" W x 14.3" D (540 x 325 x 365 mm) • Weight: 46 lbs. (21 kg).
  • Speaker TypeActive / Powered
  • Speaker Configuration3-Way
  • Woofer Size10"
  • BrandKRK Systems
  • ModelRP10-3
  • Part Number246-463
  • Product CategoryStudio Monitors
  • Weight54 lbs.
View similar products to the KRK RP10-3 RoKit 10" 3-Way Active Studio Monitor Each
in the Studio Monitors product category.
