KRK KNS 6400 Professional Monitoring Headphones
Brand:|Model: KNS 6400|Part # 246-450
Experience the latest reference quality frequency response for closed-back, circum-aural dynamic headphones with the KNS-6400 professional monitor headphones by KRK.
List Price$169.99
You Save41%
$99.99
Part # 246-450
  • Utilizing the latest in acoustic foam technology ensures class leading performance in both reproduction and isolation
  • A new standard in headphone comfort, even over extended periods of use, designed to avoid feeling uncomfortable during long sessions, the special foam conforms to the ear to help ensure an improved fit
  • Exceedingly accurate, natural and wide frequency response
  • Large dynamic range with extremely consistent low-distortion detail and clarity
  • Transparent reproduction of high-frequencies, resulting in highly accurate imaging
  • High-efficiency Neodymium 40 mm driver
  • Replaceable cable, head, and ear cushions to ensure long product life
Whether you are listening to some tracks, or tracking your next recording, the KNS-6400 gives you the famous KRK sound independent of your monitors. This closed-back around-the-ear design brings you closer to your music, and the highly isolated surround pads give you the freedom to immerse yourself in the sound without having your monitor mix "escape" into open microphones and keeps live instruments out of what you are monitoring. Having "One Voice" that consistently gives you accurate reproduction of your music or mix will help you achieve just what the artist intended, especially if the artist is you.
Performance
    • Accurate, natural and wide frequency response
    • Class leading KRK sound clarity, very low-distortion
    • Precise imaging and extended LF response
    • High isolation for both noise rejection and leakage
Utility
    • Detachable and replaceable locking cable
    • Rotating ear cups for travel and storage
    • Durable, impact resistant materials throughout
    • Replaceable ear and head cushions
Comfort
    • Lightweight construction for use over long sessions
    • Adjustable low-pressure headband system
    • Ear and head cushions utilize advanced memory foam
    • Self-aligning yoke system ensures the best possible fit
Specifications: • System: Dynamic • Operating system: Closed-back • Head coupling: Circumaural (isolating) • Voice coil: Copper-clad aluminum wire • Driver type: Low weight neodymium • Driver diameter: 40 mm • Sensitivity: 95 dB SPL @ 1m/1W • Frequency response: 10 Hz-22 kHz • THD: <0.1% • Rated impedance: 36 ohms • Ambient noise isolation: Up to 26 dBA  • Long term maximum power handling: 1000mW (500mW per side as per IEC 60268-7) • Earcup rotation: 90 degrees • Nominal headband pressure: 4 N (based on average head size) • Headband type: Adjustable/Sprung steel skeleton • Ear cushion type: Acoustic cellular foam • Headpad finish: Leatherette • Headphone finish: Black impact resistant plastic • Cable: 2.5 m, (8.2 ft.), 99,99% OFC detachable • Connector: Gold-plated stereo 1/8" (3.5 mm) • Cable connection: Strain relief managed • Adapter: Screw-on 1/4" (6.3 mm) • Weight without Cable: 0.44 lbs. (202 g) • Dimensions: 9.6" x 10.5" x 3.7" (245 x 268 x 94 mm).
KRK Headphones provide a precise listening experience that takes you from personal studio to commercial studio to on-the-go track evaluations -- and they allow you to accurately enjoy your music with the consistent voicing philosophy and honest reproduction top producers, studio musicians, performers and engineers have come to trust. KRK headphones provide incredibly natural frequency response that gives you a reference standard unaffected by your location. Day or night. Studio or home. Without disturbing others. Without compromising your tracks. Passionate about music and interested in experiencing the artist's vision as it was intended to be heard? Then experience KRK.
  • Special FeaturesFoldable Collapsible
  • Fit StyleOver-the-Ear
  • Type or Typical UseProfessional / DJ
  • ColorBlack
  • BrandKRK Systems
  • ModelKNS 6400
  • Part Number246-450
  • UPC816654002594
  • Product CategoryHeadphones
  • Weight1.85 lbs.
View similar products to the KRK KNS 6400 Professional Monitoring Headphones
in the Headphones product category.
