300-7079_ALT_0
300-7079_ALT_1
300-7079_ALT_2
Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO Subwoofer
This four cubic foot cabinet is precision CNC-machined for finished professional results without tools! Build a beast of a subwoofer using this cabinet and the Dayton Audio Reference Series RSS460HO-4 18" subwoofer.
  • 4.0 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio Reference Series 18" High Output subwoofer
300-7079
Weight: 61.25 lbs.
IN STOCK
List Price$199.99
You Save24%
$150.00
Part # 300-7079
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 18" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 18-3/16" or less, and a cutout requirement of 16-3/4" or less. The sealed enclosure design creates a subwoofer system with a Qtc of 0.644 and an f3 of 40 Hz when used with the Dayton Audio RSS460HO-4 and minimal fill. Adding five pounds of Acousta-Stuf will create a critically damped subwoofer system.
During the CNC manufacturing process, rabbets dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 18" High Output Reference Series subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle and bracing): 4.0 cubic feet • External dimensions: 20" H x 23" W x 20.75" D • Subwoofer recess: 1/2" • Weight: 62 lbs. • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7079
  • UPC848791000706
  • Product CategorySubwoofer Speaker Cabinets
    (1 Reviews)
  • Weight61.25 lbs.
View similar products to the Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO Subwoofer
in the Subwoofer Speaker Cabinets product category.
Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO Subwoofer is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Spend a little money, save a lot of timeThis enclosure went together flawlessly. I could have built it myself, but it would have taken the better part of a day. The CNC routered parts are nice, and everything is slotted / indexed. Tossing it together, carpeting it, and dropping in my JL 18W6 took about 3 hours with taking my time.As soon as I get the amplifiers wired, I'll drop it in the truck and see what it can do.
Date published: 2013-08-26
I have a Focal 46-KX-4 18" QVC subwoofer that I want to install in this.  What would the port length need to be?  Here are the specs from Focal: http://www.focal.com/en/k2-power/89-46-kx-4-3544055751342.html
Asked by: SkulliWulli
The most practical port for this enclosure and that woofer would be a 6" diameter, 15" long dual flared port. This would tune the box to 32 Hz and probably have to be rear mounted.
Date published: 2014-09-05
The header says its a 4.0cf enclosure, but the highlights description says 1.25cf   Is this a typo?
Yes this is a typo and will be fixed. This enclosure is 4.0 cubic feet.
Is there a knock down cab available for dual 18" subs?
Asked by: CaptainOpus
Unfortunately we do not have a cabinet available for dual 18" subs at this time.
Date published: 2014-06-09
I would prefer a ported 18' enclosure.  What would be the easiest way to port this, or do you sell a ported 18 inch enclosure?
Asked by: Kevings
Unfortunately we do not sell a ported enclosure for an 18. You will have to add a port to one of the sides or the back of the enclosure.
Date published: 2014-04-17
The description says "Plate amplifier installation is made easy by following the scribed interior guide with a jig saw". Obviously the size of that cutout is for a specific plate amp; does anyone know which one it is?
Asked by: jleonard711
This cutout will work with either the SPA500 or SPA1000 from Dayton Audio.
Date published: 2014-03-06
Would this box also be used for the now delayed UM18-22 ? If not is there going to be a bundle with the UM18-22 and a knock down cabinet for the new model?
Asked by: Haoleman
This volume will work well for the UM18 woofer, however the baffle will need to be modified to fit it. There is a good chance we will have a knock down enclosure for the 18" model when it is available.
Date published: 2014-03-19
Customer projects that include: Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO Subwoofer
