300-7079_ALT_0
300-7079_ALT_1
300-7079_ALT_2
300-7079_ALT_3
Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO or Ultimax Subwoofer
This four cubic foot cabinet is precision CNC-machined for finished professional results without tools! Build a beast of a subwoofer using this cabinet and the Dayton Audio 18" Reference Series RSS460HO-4 or Ultimax UM18-22 driver.
  • 4.0 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio 18" Ultimax or Reference Series High Output subwoofers
300-7079
Weight: 61.25 lbs.
IN STOCK
List Price$199.99
You Save17%
$165.00
Part # 300-7079
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 18" Ultimax or Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 18-1/4" or less, and a cutout requirement of 16-3/4" or less. The sealed enclosure design with minimal fill creates a subwoofer system with a Qtc of 0.644 and an f3 of 40 Hz when used with the Dayton Audio RSS460HO-4, or for the Ultimax a Qtc of 0.714 with an F3 of 32. Adding five pounds of Acousta-Stuf will create a critically damped subwoofer system.
During the CNC manufacturing process, rabbets dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 18" Ultimax or High Output Reference Series subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle and bracing): 4.0 cubic feet • External dimensions: 23" H x 20" W x 20.75" D • Subwoofer recess: 1/2" • Weight: 62 lbs. • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7079
  • UPC848791000706
  • Product CategorySubwoofer Speaker Cabinets
    (1 Reviews)
  • Weight61.25 lbs.
View similar products to the Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO or Ultimax Subwoofer
in the Subwoofer Speaker Cabinets product category.
Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO or Ultimax Subwoofer is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Spend a little money, save a lot of timeThis enclosure went together flawlessly. I could have built it myself, but it would have taken the better part of a day. The CNC routered parts are nice, and everything is slotted / indexed. Tossing it together, carpeting it, and dropping in my JL 18W6 took about 3 hours with taking my time.As soon as I get the amplifiers wired, I'll drop it in the truck and see what it can do.
Date published: 2013-08-26
  • 2015-03-04T06:25CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_300-7079, PRD, sort_mostRecent
How deep can a subwoofer be before it hits the bottom of the box?
Asked by: throwaway69
Do yall sell any speakers grills made for this box?
Asked by: Blutengel
We do not have any made specifically for these enclosure, but we do sell a grill frame kit that you can cut to size to fit.http://www.parts-express.com/parts-express-speaker-grill-frame-kit--260-346
Date published: 2015-02-05
Is it possible to order these knock downs in birch  plywood"
Asked by: Fritzer
Currently only available in Medium Density Fiberboard. ( MDF)
Answered by: TomI
Date published: 2015-02-03
Hi. Can this cabinet fit si hst18? outer diamter for this sub is 18,42 Thx in advance..
Asked by: opec
This cabinet has a maximum cutout of 18-1/4" so it would need to be modified to fit that woofer.
Date published: 2015-01-22
I would like to use this cab for pro audio subs , using eminence omega pro 18" subs what would you recommend for porting and fill.. if any
Asked by: Boochie
I would recommend a 6" diameter port that is 12" long for a tuning frequency of 33 Hz in this volume. Fill is not necessarily required for this type of application but you could line the walls with some standard fiberglass insulation.
Date published: 2014-10-27
Few questions: I'd like to use this for PA purposes (using JBL 515XTs right now)... would you suggest this in pairs only? Is this big enough to use with a mount pole and put my JBLs on top safely?
Asked by: D Jay Cee
Yes you could use the MDF subwoofer cabinet for PA use although it is designed for home audio applications. Utilizing one or two subs would depending on the venue size. I would caution using these with long poles for fear of tipping. Shorter pole would have a stronger center of gravity. The weight of the Jbl 515xt is 32.5 and the sub box empty is 61.25 lbs.
Answered by: TomI
Date published: 2014-10-09
  • 2015-03-04T07:50CST
  • co_hasquestionsanswers, tq_15
  • loc_en_US, sid_300-7079, PRD, sort_recentQuestionsFirst
Customer projects that include: Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO or Ultimax Subwoofer
