300-7078_ALT_0
300-7078_ALT_1
300-7078_ALT_2
Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for Dayton Audio 15" Reference Series HO Subwoofer
Build the ultimate subwoofer using this extremely rigid, knock-down, three cubic foot subwoofer cabinet. Extremely well thought out, this cabinet includes precision-machined panels that include dadoes, a double-thick front baffle, and a unique two-piece brace system.
  • 3 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio RSS390-4 Reference Series High Output subwoofer
300-7078
Weight: 52 lbs.
IN STOCK
List Price$169.99
You Save26%
$125.00
Part # 300-7078
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 15" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 15-3/8" or less, and a cutout requirement of 14-1/16" or less. The sealed enclosure design creates a critically damped subwoofer system when used with the Dayton Audio RSS390HO-4.
During the CNC manufacturing process, rabbets dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 15" High Output Reference Series subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 3.0 cubic feet • External dimensions: 19.25" H x 19.25" W x 20" D • Subwoofer recess: 7/16" • Weight: 52 lbs. • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7078
  • UPC848791000690
  • Product CategorySubwoofer Speaker Cabinets
    (2 Reviews)
  • Weight52 lbs.
View similar products to the Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for Dayton Audio 15" Reference Series HO Subwoofer
in the Subwoofer Speaker Cabinets product category.
Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for Dayton Audio 15" Reference Series HO Subwoofer is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Easiest sub build ever!The kit arrived on time and in perfect condition. The CNC cut parts fit with absolute precision. Being a freak about box resonance, I added extra stiffening to the larger box walls (made use of some MDF scrap in my shop) but I doubt any put the pickiest would hear the difference. Unless you have specific dimensional requirements to fit in a particular location, you are money ahead buying this kit Vs. gas/time/hassle of getting/cutting/fabricating from raw stock MDF.
Date published: 2014-02-19
Rated 5 out of 5 by from Good ValueBought this (the second one) to mount one of the Reference speakers in. With a little care in assembly it will come out great. Since both of them are hidden from sight I opted not to paint them.Drilling the holes for the speaker is critical because there is so little clearance. It would be easy to break out the edges but it can be done.
Date published: 2014-01-30
  • 2015-03-03T06:22CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_300-7078, PRD, sort_mostRecent
Is there enough room in the bottom front corners of this enclosure to install a pair of Precision Port 2" Flared Speaker Cabinet Port Tubes? The parts-express Part # 268-348, and the outside flare diameter is 5-1/4".
Asked by: mustang guy
Unfortunately no, the flared ports would have to be mounted on the side or rear of the enclosure.
Date published: 2015-02-11
Just trying to make sure if the Dayton Audio 15" Titanic Mark III will fit in this cabinet.
Asked by: Snowman_
The Titanic 15 will work well in the volume although the baffle will need to be cut out larger to accommodate the woofer since the frame of the Titanic is slightly larger.
Date published: 2014-11-10
Would this cabinet work for a 15 inch co-axial altec lansing voice of the theater speaker
Asked by: Richmd
This box is intended for the RSS390, which has a little larger frame than typical. The cutout for that is 14.03 and the outside diameter is 15.29 inches.
Answered by: Chrisf
Date published: 2014-06-03
What tools are needed to assemble it? Can I leave it unfinished - just for now --- Thanks, Robert
Asked by: Robert605
These cabinets can be assembled with standard wood glue and clamps. Finishing is completely optional.
Date published: 2014-05-27
Hi, will the  HF model (corresponds to HO?) be able to utilize this same cabinet?
Asked by: Robert605
Yes either model will work in that cabinet.
I was planning on using 1" dia alum round stock threaded right hand on one end and left hand on the other to use as internal bracing. These would thread into custom mounting blocks mounted on each end of the internal cabinet. Would this help stiffness?
Asked by: georgexr400
It would probably help but I doubt it will be worth the effort involved. These cabinets are very well braced as they come and additional bracing is not required.
Date published: 2014-04-28
  • 2015-03-02T08:57CST
  • co_hasquestionsanswers, tq_9
  • loc_en_US, sid_300-7078, PRD, sort_recentQuestionsFirst
Customer projects that include: Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for Dayton Audio 15" Reference Series HO Subwoofer
