300-7080_ALT_0
300-7080_ALT_1
300-7080_ALT_2
Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer
Build the ultimate subwoofer using this precision CNC-machined subwoofer cabinet that is purpose built to use with Dayton Audio's 10" Ultimax subwoofer.
  • 1.25 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio Ultimax 10" subwoofer
300-7080
Weight: 34.9 lbs.
IN STOCK
$95.00
Part # 300-7080
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 10" Ultimax subwoofer, but works for any subwoofer with an overall diameter of 10-3/4" or less, and a cutout requirement of 9-9/16" or less. When used together with minimal fill, the box and subwoofer combine to create a critically damped subwoofer with a Qtc of 0.589 and an f3 of 45 Hz.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with rabbeted recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 10" Ultimax subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 1.25 cubic feet • External dimensions: 15.25" H x 15.25" W x 15.25" D • Subwoofer recess: 1/2" • Weight: 35 lbs. • Made in the U.S.A.
  • BrandDenovo Audio Inc
  • Part Number300-7080
  • UPC848791000713
  • Product CategorySubwoofer Speaker Cabinets
    (2 Reviews)
  • Weight34.9 lbs.
View similar products to the Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer
in the Subwoofer Speaker Cabinets product category.
Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from You can make a very nice cabinet with this kitIf you take the time to sand and finish, you can have a VERY nice very professional subwoofer cab with this kit. I am very happy with how this build came out A+++++
Date published: 2014-06-06
Rated 5 out of 5 by from Inspect Carefully Before AssemblyI should have been more careful and inspected every part of the kit before assembly. UPS seems to have dropped the kit in such a way as to damage one corner of the kit. The Parts Express packaging job was very good but further inspection of the box it came in showed obvious signs of UPS gorillas. It isn't a deal breaker, and some strong clamps and creative use of them made things O.K., but I had already cut out the back for the plate amp and if the damage was any worse I would have been out of warranty and out of luck.That being said, the kit is very nice and easy to assemble. The machine work makes the kit quick to assemble and VERY strong.
Date published: 2014-01-18
  • 2015-05-25T07:20CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_300-7080, PRD, sort_mostRecent
Would you recommend this enclosure for use with the TC Epic 10?
Asked by: Bendoe
The cabinet cutout may need to be slightly modified for it to fit properly, but the volume will work well with that woofer.
Date published: 2015-05-10
do I get 4 boxes if I buy 4 speakers???
Asked by: Gazza
Thanks for the question!It seems you question is attached to the cabinet, directly, instead of a speaker. We are currently offering these for free with the purchase of a Morel 10" subwoofer. With that promotion, you would receive one box for each subwoofer purchased, and four boxes for four subwoofers purchased.Here are the Morel subwoofers that the offer applies to:http://www.parts-express.com/morel-ultimate-uw-1058-10-subwoofer--297-130http://www.parts-express.com/morel-ticw-1058ft-titanium-series-10-subwoofer-8-ohm--297-109
Answered by: mikevv
Date published: 2014-12-08
It looks like it would work alright, but what are your thoughts on using this box with a Dayton Audio RSS265HF-8 10" Reference HF? I purchased two for use in a couple of homemade tube enclosures, but am having second thoughts.
Asked by: 16X4ME
The volume of the enclosure will work well. The cutouts will be slightly oversized for the Reference woofer but it will still fit snug in the through hole.
Date published: 2014-07-17
Hi...do you guy's have some custom boxes for car audio application?
Asked by: Ej33
Unfortunately we do not have any custom enclosures for car audio at this time.
Date published: 2014-05-06
How can I install the plate amp (SPA250) for downfiring position?
Asked by: cardo
I see no way of this working unless you use different braces, the length from box wall to brace is 6.5". Your other option with that amp is to make a box for it.
Answered by: DycesKynes
Date published: 2013-09-17
  • 2015-05-25T09:12CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_300-7080, PRD, sort_recentQuestionsFirst
Customer projects that include: Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer
