300-7066_ALT_0
Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
Build your own tower speaker cabinet in minutes with this CNC-cut cabinet.
  • CNC-cut, acoustically inert MDF panels for precise fit and finish
  • 1.16 cu. ft. internal volume
  • Build your own tower or large format center channel speaker
  • Assembles in minutes
  • Made in the U.S.A.
300-7066
Weight: 27.75 lbs.
IN STOCK
List Price$79.99
Regular Price$65.74
You Save16%
Special Price
$55.00
Part # 300-7066
CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills, perfect for DIYers without expensive tools or access to a woodshop.
During the CNC process, dadoes are cut into the top, bottom, and rear panels to ensure a tight, secure fit that maximizes the gluing surface and making assembly that much easier. This tower cabinet allows you to create your very own front left or right tower speaker... or even a large format center channel speaker! Three included window braces add structural integrity while consuming as little internal volume as possible.
Additionally, users can mount side-firing a woofer (up to 8" maximum is recommended) for a modern 3-way design. The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
Note: Panel dimensions and a 3D SketchUp model are included in the Manuals/Resources section. To open and use the 3D model, you need to download and install a program to unzip the file (7-Zip is free and recommended) and then download and install SketchUp to open the .skp file.
Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished cabinet volume: 1.16 cubic feet • External dimensions: 34" H x 8" W x 11" D • Internal dimensions: 32-1/2" H x 6-1/2" W x 9-1/2" D • Made in the U.S.A. • Sold individually.
  • BrandParts Express
  • Part Number300-7066
  • UPC844632007286
  • Product CategoryKnock-Down Speaker Cabinets
    (2 Reviews)
  • Weight27.75 lbs.
View similar products to the Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
in the Knock-Down Speaker Cabinets product category.
Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from About what I expectedI found these cabinets easy to assemble. I used the rear panel to hold the braces in place while I applied glue to the side panels. I'll finish gluing on the rear and front panels after I drill vent hole and apply my finish to the front baffle.I didn't have to use a mallet but clamps help to hold things in place while the glue sets up. I used plain yellow wood glue.
Date published: 2014-01-30
Rated 3 out of 5 by from This cabinet is ok..IF you know what you are doing,IF you get ALL corners trued..This product needs some helpful hints or instructions.
Date published: 2014-04-19
What would the reccomended set be for these cabinets i/e speakes and crossovers ?
Asked by: AVguy
I designed a budget friendly speaker around this cabinet using all parts sourced from PE.The crossover works with both the tower and center configuration. The cabinet is sealed, vented is not an option with this woofer in a cabinet this size.
Answered by: Jay1
Date published: 2013-07-04
Judging from the dimensions, is it safe to say that this cabinet is to small for a 10 inch woofer, or would mounting it on the 11 inch depth side
inhibit performance, or mounting on top or bottom of box .300-7066 : Knock-Down MDF 1.16 ft³ Tower Speaker CabinetRoll over image to zoomClick to see larger300-7066300-7066Knock-Down MDF 1.16 ft³ Tower Speaker Cabinet
Asked by: Hobbyguy
The answer is "it depends". The first thing to check is the required internal volume for your driver of choice, in the design you have selected (ported or closed) at the F3 you have chosen as the target. The second point is to be mindful of the enclosure's internal dimention; it is only 9.25", which is insufficient to avoid compression on many 10" nominal drivers. The last point is that side mounting a woofer requires crossover changes specifically for this mounting option.As another option, you might also consider rounding-over all the edges for the same cosmetic appearance as the front baffle. Then you could rotate the enclosure 90 degress and turn the "side" into the "front".Cheers
Answered by: platoindy
Date published: 2013-08-25
access for crossover maintenance
I'm wondering how to provide access to the crossover when using this cabinet without making a mess. I'm looking to avoid exposed screws. Can the bottom be secured effectively on all four sides using pocket screws?
Asked by: aespen
You can have access to the crossover IF you make the crossover smaller than the smallest speaker, OR you can attempt to make a removable baffle, I tried the latter (epic fail)
Answered by: Steven72555
Date published: 2013-10-24
How many inches between each brace?
Asked by: VusstoppyPro
There is 7-1/2" of space between each brace.
Customer projects that include: Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
