300-7076_ALT_0
300-7076_ALT_1
300-7076_ALT_2
Knock-Down MDF 1.0 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Reference Series HO Subwoofer
This superior subwoofer cabinet is CNC-machined for precise panels and is specifically built for use with the Dayton Audio RSS265HO-4 and a plate amplifier with bass boost.
  • 1 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio RSS265HO-4 10" subwoofer when used with a plate amp with bass boost
300-7076
Weight: 29 lbs.
IN STOCK
List Price$129.99
You Save37%
$81.67
Part # 300-7076
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 10" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 10-9/16" or less, and a cutout requirement of 9-1/4" or less. The larger than optimal sealed enclosure design, when used with the Dayton Audio RSS265HO-4, mates extremely well with the Dayton Audio SPA250 plate amplifier with boost set to on, or the Dayton Audio SPA500 (with the parametric EQ set to 32 Hz, bandwidth set to 1, and level set to +6). This allows for an extremely low f3 without the "one-note-bass" droning typically found with bass boosted sealed subwoofers.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with rabbeted recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 10" High Output Reference Series subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 1.0 cubic feet • External dimensions: 14.25" H x 14.25" W x 15" D • Subwoofer recess: 1/2" • Weight: 29 lbs. • Made in the U.S.A.
  • BrandDenovo Audio Inc
  • Part Number300-7076
  • UPC848791000676
  • Product CategorySubwoofer Speaker Cabinets
    (1 Reviews)
  • Weight29 lbs.
View similar products to the Knock-Down MDF 1.0 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Reference Series HO Subwoofer
in the Subwoofer Speaker Cabinets product category.
Knock-Down MDF 1.0 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Reference Series HO Subwoofer is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Good box to get yourself rolling quicker than scratchGlad to see that PE is selling cabinets like these again. I bought another version over 9 years ago for the 12" Reference RSS315HF-4 woofer and it was excellent. I didn't find this quite as easy to assemble, especially for the inexperienced builder (which I'm not). It could have had more rabbets to help with the assembly but with a little care you can still assemble it easily (or use screws).I had to make many alterations to the cross bracing to get the Dayton SPA500 to fit in this enclosure but the RSS265HO-4 fit perfrectly. I haven't had to chance to listen to it so I'll post those impressions later.One thing I thought was odd was that the 1.25 ft^3 enclosure for the Dayton Ultimax driver was $13 cheaper. No idea why.
Date published: 2013-07-22
  • 2015-05-05T06:43CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_300-7076, PRD, sort_mostRecent
How does a plate amp fit through the back with the brace blocking the cut-out area?
Asked by: Geoffrey
There are perforated line on the back where you can knock out for a plate amp. The bracing is inset slightly to leave room for the amp.
Answered by: TomI
Date published: 2015-04-07
I rather use it with RSS265HF-4. It seems perfect. Why is it not mentioned (auto application)?
Asked by: Slowpoke Rodriguez
This cabinet will work well for many 10 subwoofers, we simply cannot list them all. The RSS265HF-4 would be a good choice.
Date published: 2014-03-18
  • 2015-05-05T09:46CST
  • loc_en_US, sid_300-7076, PRD, sort_recentQuestionsFirst
Customer projects that include: Knock-Down MDF 1.0 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Reference Series HO Subwoofer
