300-7075_ALT_0
300-7075_ALT_1
300-7075_ALT_2
Knock-Down MDF 0.75 cu. ft. Subwoofer Cabinet for Dayton Audio 8" Reference Series HO Subwoofer
This 0.75 cubic foot cabinet is precision CNC-machined for finished professional results without tools! Build a beast of a subwoofer using this cabinet and the Dayton Audio Reference Series RSS210HO-4 8" subwoofer.
  • 0.75 cubic foot cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • CNC-machined dadoes, subwoofer cutout and recess, and a unique bracing system that increases cabinet rigidity
  • Designed specifically for the Dayton Audio Reference Series High Output 8" subwoofer
300-7075
Weight: 24.5 lbs.
IN STOCK
List Price$99.99
You Save28%
$71.67
Part # 300-7075
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
This particular cabinet is designed specifically for the Dayton Audio 8" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 8-1/2" or less, and a cutout requirement of 7-3/8" or less. The sealed enclosure design creates a subwoofer system with a Qtc of 0.644 and an f3 of 40 Hz when used with the Dayton Audio RSS210HO-4 and minimal fill. Adding five pounds of Acousta-Stuf will create a critically damped subwoofer system.
During the CNC manufacturing process, rabbets dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 8" High Output Reference Series subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle and bracing): 0.75 cubic feet • External dimensions: 13" H x 13" W x 13.75" D • Subwoofer recess: 1/2" • Weight: 20 lbs. • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7075
  • UPC848791000669
  • Product CategorySubwoofer Speaker Cabinets
    (1 Reviews)
  • Weight24.5 lbs.
View similar products to the Knock-Down MDF 0.75 cu. ft. Subwoofer Cabinet for Dayton Audio 8" Reference Series HO Subwoofer
in the Subwoofer Speaker Cabinets product category.
Knock-Down MDF 0.75 cu. ft. Subwoofer Cabinet for Dayton Audio 8" Reference Series HO Subwoofer is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Very Well Designed!I used this with a different Dayton Audio driver than it was designed for. It seems like it would work with a large variety of subs. I am very impressed with the fit and design. It is well packaged and all pieces arrived in good shape. I put it together in my living room without the need for instructions.Great job!
Date published: 2013-07-23
  • 2015-01-31T22:45CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_300-7075, PRD, sort_mostRecent
Would this be a good enclosure for the TC Sounds Epic 8" DVC Subwoofer?
Asked by: cbas
This volume will work well for that woofer. The baffle may need to be modified in order for it to fit properly.
Date published: 2014-11-05
Any advice for gluing this cabinet together? It seems like most people online recommend Titebond 2 for MDF. Also, some people seem to recommend applying a first coat of glue and drying to seal the ends, then applying a second for final assembly...
Asked by: JoelD
Titebond II is perfect for MDF and generally creates a stronger bond than the wood itself. As for sealing up MDF edges, there are many methods for this, I would recommend searching for different methods online.
Date published: 2014-05-27
  • 2015-01-31T23:41CST
  • loc_en_US, sid_300-7075, PRD, sort_recentQuestionsFirst
Customer projects that include: Knock-Down MDF 0.75 cu. ft. Subwoofer Cabinet for Dayton Audio 8" Reference Series HO Subwoofer
