Knock-Down Birch 0.60 cu. ft. Monitor Cabinet
Brand:|Part # 300-7050
Build your own monitor speaker in minutes with this CNC-cut cabinet.
  • Made in the U.S.A.
  • Beautiful seven-ply, 1/2" birch construction
  • Unlimited finishing options
  • Perfect size for bookshelf speakers or desktop monitors
  • Dadoed top, bottom, and sides to maximize the gluing surface
  • Two shelf braces included for subdividing internal airspace
CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills, perfect for DIYers without expensive tools or access to a woodshop. This cabinet was designed using the Golden Ratio to minimize cabinet resonances.
During the CNC process, dadoes are cut into the top, bottom, and side panels to ensure a tight, secure fit, maximizing the gluing surface and making assembly that much easier. Once the outer shell is constructed, the front and rear baffles drop into recessed pockets to ensure rigidity.
This monitor cabinet allows you to create your very own bookshelf speaker, monitor, or a stand mounted main speaker. Two included shelf braces allow the option of creating two separate internal volumes of 0.19 and 0.39 cubic feet or three separate internal volumes of 0.19 cubic feet or, with the use of a hole saw, create window braces that don't effect the internal volume at all.
Additionally, users can front mount the drivers for a classic look or side mount the drivers for a more modern look, minimizing the width and even side-firing a woofer for a miniature 3-way design. The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
The final finish? Sand and stain, paint, cover with veneer... your options are unlimited.
Specifications: • Panel thickness: 1/2" • Panel material: Multi-ply birch • Finished cabinet volume: 0.60 cubic feet • External dimensions: 17" H x 11" W x 7.5" D • Internal dimensions: 16" H x 10" W x 6.5" D • Shelf distance from the inside bottom of the cabinet: 5-1/16", 10-9/16" • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7050
  • UPC844632093937
  • Product CategoryKnock-Down Flat-Pack Speaker Cabinets
    (1 Reviews)
  • Weight8.4 lbs.
Videos
