Knock-Down Birch 0.58 cu. ft. Subwoofer 11" Cube Cabinet
Brand:|Part # 300-7042
Build your own computer or surround sound subwoofer with this CNC-cut 11" cube cabinet in minutes.
  • Beautiful seven-ply, 1/2" birch panels
  • Unlimited finishing options
  • Perfect size for computer subwoofers and apartment subwoofers
  • Dadoed top, bottom, and sides to maximize the gluing surface
  • 11" cube with 0.58 cubic foot volume for small subwoofers
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. Perfect for DIYers without expensive tools or access to a woodshop.
During the CNC process, dadoes are cut into the top, bottom, and side panels to ensure a tight, secure fit, maximizing the gluing surface and making assembly that much easier. Once the outer shell is constructed, the front and rear baffles drop into recessed pockets to ensure rigidity.
The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
The final finish? Sand and stain, paint, cover with veneer... your options are unlimited.
Specifications: • Panel thickness: 1/2" • Panel material: Multi-ply birch • Finished cabinet volume: 0.58 cubic feet • External dimensions: 11" H x 11" W x 11" D • Internal dimensions: 10" H x 10" W x 10" D • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7042
  • UPC844632093890
  • Product CategoryKnock-Down Flat-Pack Speaker Cabinets
    (2 Reviews)
  • Weight6.7 lbs.
Videos
