310-142_ALT_0
310-142_ALT_1
310-142_ALT_2
310-142_ALT_3
Kinyo SB-033D 2.0 Powered Speaker Bar
Brand:|Model: SB-033D|Part # 310-142
Looking for better sound from your TV without devoting the space or budget to a full-fledged home theater? The Kinyo SB-033D is a simple, affordable solution.
  • Full-function slim remote
  • Subwoofer output for adding a powered sub
  • BassRenu radiators help low-end heft
The Kinyo SB-033D speaker bar is an ideal way to get better sound from your TV. If dialog intelligibility is a problem, the SB-033D is the solution, utilizing two 2" x 3" full-range drivers and two 2" tweeters behind an attractive metal grill. Kinyo's Bass ReNu radiators help add a surprising degree of low-end authority, as well.
There are two analog inputs: a pair of RCA jacks on the back for the TV or cable box, and a 3.5mm jack placed conveniently on the top for an MP3 player or other audio source. There's also a subwoofer output, so the SB-033D can be connected to a powered subwoofer (not included) for even greater bass impact.
A slim remote gives you all the same controls you'll find on the SB-033D, as well as five different EQ presets to tailor the sound to your room and tastes.
Mounting is simple. Either set the SB-033D on its rubber feet, or use the included hardware and integrated mounting brackets to put it on the wall below your TV.
Specifications: • Power output: 2 x 10w RMS • Frequency response: 120-20,000 Hz • Dimensions: 28.98" W x 2.76" H x 2.83" D.
  • Special FeaturesSpeaker Bar,Powered
  • Woofer Diameter3" x 2"
  • Configuration2-way (MTM)
  • ColorBlack
  • BrandKinyo
  • ModelSB-033D
  • Part Number310-142
  • UPC031752993579
  • Product CategorySound Bars / Speaker Bars
  • Weight4.5 lbs.
View similar products to the Kinyo SB-033D 2.0 Powered Speaker Bar
in the Sound Bars / Speaker Bars product category.
