310-380_ALT_0
310-380_ALT_1
310-380_ALT_2
310-380_ALT_3
310-380_ALT_4
Kinter A7 2-Ch Mini Amplifier for Motorcycles with IR and Handlebar Mount Remotes USB MP3 2x20W
Brand:|Model: A7|Part # 310-380
The Kinter A7 amplifier, their smallest, is the only mini amp that's designed specifically for motorcycle applications. Thanks to the A7's included handlebar remote, it's easy to add power and control to your mobile audio application.
List Price$24.99
You Save31%
$17.20
Buy 5+$15.60
Part # 310-380
  • 2-channel amplifier design with 20 watts per channel
  • Wired handlebar and wireless infrared remote controls included
  • Digital audio player with USB and micro SD card inputs
  • Pushbutton playback controls
  • Built-in FM tuner
  • Headphone output jack with included in-ear headphones
  • Power supply sold separately
Deceptively small, the Kinter A7 mini amp plays it big! Designed for motorcycle applications, the A7 amplifier features an external wired handlebar remote control that controls playback and volume functions. The A7 can be loaded with either a TF flash memory card (Mini-SD type) or a USB flash drive full of your favorite songs. Play your music out loud with 20 watts of power into two channels, or listen solo with the included earbuds!
Specifications: • Power output: 2 x 20 watts • Input impedance: 47K ohms • Output impedance: 4 - 8 ohms • Frequency response: 20 - 20,000 Hz • Minimum THD: ≤0.02% • Input voltage: 9 - 14.4 VDC • Rated input current: 1A - 3A • DC plug size: 2.1 mm x 5.5 mm • 12V power supply sold separately • Must be mounted in ventilated area • Dimensions: 3-1/2" L x 1" W x 2-3/4" D.
  • Special FeaturesRemote Control,SD Card Input,USB Connectivity
  • BrandKinter
  • ModelA7
  • Part Number310-380
  • UPC848864015309
  • Product CategoryHome Audio Amplifiers
    (4 Reviews)
  • Weight0.4500 lbs.
View similar products to the Kinter A7 2-Ch Mini Amplifier for Motorcycles with IR and Handlebar Mount Remotes USB MP3 2x20W
in the Home Audio Amplifiers product category.
Kinter A7 2-Ch Mini Amplifier for Motorcycles with IR and Handlebar Mount Remotes USB MP3 2x20W is rated 4.25 out of 5 by 4.
Rated 5 out of 5 by from Great FMHooked it up to a 25 watt Meanwell power supply and a couple of 12" coax speakers- fills the room with lots of radio. For $17 don't whine about the sound quality and if you are listening to your local FM station in the house all day it's prefect!
Date published: 2015-01-16
Rated 3 out of 5 by from Amazing FM StereoI needed a low cost solution for FM and MP3 with a headphone level output solution, and works great (sound is superb) for that purpose. Do not expect 20 W per channel, which I do not use anyway. I set up for a near field 2.1 stereo retired from an old PC that offers a great sub-woofer response. I tried at first with the separately purchased 12V 1200mA power adapter, but the hum noise level was too high (because the Kinater A7 is intended for 12 V motorcycle battery), I had to use a clean DC supply. It comes infra red and wired remote controls, but the 3-button function is far from convenient. I have no way knowing in what mode it is in especially for FM. Once it picks up a favorite station, hope it will not continue scanning. If it sates on, the stereo effect (called ST Separation) is amazingly clear. MP3 has nor problem, it also plays .WAV format directly "Grabbed" from CD. "Ripped" format did not work.
Date published: 2014-11-16
Rated 4 out of 5 by from Great amp for the priceThis is a good little amp/digital player for it's size, features and cost. The FM radio is a huge plus though a little finicky to switch stations. It sounds better than it's size and cost would imply.
Date published: 2014-09-26
Rated 5 out of 5 by from SURPRISE, It tunes FM stereo too !!I was surprised to see this unit. I had looked at it but decided to buy something else. After re-reading the information I'm not sure the description leaves you with a solid impression of the factuality of it. It IS a 2-channel amplifier and the handlebar mountable control lends itself to any installation such as a motorcycle though... why limit this device to motorcycles?? sources are ,usb for thumb drive, a mini SD slot, an onboard FM tuner that has a quirky interface that would seem to be a bump-seek rather than scan to allow easy use while piloting a vehicle of any kind, high or low speed. To be clear there are no provisions for external sources, and while 20 watts seems impossible for the size of it my limited power supply disqualified me from testing output power though the clarity of the audio was quite distinct and profound. That quality alone would make this a candidate for installation anywhere 12v and speakers can be provided. Let one surprise you.
Date published: 2014-08-06
  • 2016-02-11T06:32CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_310-380, PRD, sort_mostRecent
Does this amp have bass and treble?
Asked by: Antonio D
This does not feature any bass or treble controls
Answered by: Chrisf
Date published: 2016-01-28
Can the mp3 or usb tracks be put on repeat?
Asked by: jtothat
Not through this unit but it could through the MP3 player or USB device if available.
Answered by: TomI
Date published: 2015-05-08
does the usb jack supply usb power to the unit attached (ie for charging)?
Asked by: sammy_roebuck
No, this USB will only work for a flash drive.
Date published: 2014-11-24
I have several questions...First, is the antenna built in? Second, what is IR and is that a port under it? Third how do I wire for car use dc to dc to meet the 1-3 Amp requirements? I don't want to use a cig. lighter adapter. Thanks!
Asked by: Vintage Rebuilder
Yes the antenna is built in and can be seen in the pictures between the headphone jack and remote line input. The IR is for the remote, the "eye" below it is the target for the remote. These can be wired to any of the power sources in the car, the easiest would probably be to the fuse box wired to something that is only on when the car is on. You can use a DC cable like below to do this.http://www.parts-express.com/21mm-x-55mm-x-112mm-dc-plug-with-6-ft-cord--090-489
I see an antenna in the back, however there is no mention of a radio. Does it have a radio?
Asked by: bbs3834
Yes this does have an FM radio which is controlled entirely by the remote. When no USB or SD card is plugged in, the unit defaults to the radio.
Date published: 2014-08-31
Is the headphone jack (in the display picture) an input or output jack? The manual picture says it is a auxiliary input. If not, where do you input the signal to be amplified?
Asked by: trainpain
The headphone jack is an output. The inputs for this amplifier are only available as USB or SD inputs, there is no AUX input via 3.5mm.
Date published: 2014-07-01
  • 2016-02-11T07:20CST
  • co_hasquestionsanswers, tq_8
  • loc_en_US, sid_310-380, PRD, sort_recentQuestionsFirst
Videos
