Kicker ZX700.5 ZX Series 4x85W + 1x420W Bridgeable Multichannel Car Audio Amplifier
Brand:|Model: ZX700.5|Part # 267-6950
Each Kicker ZX Series amplifier is factory tested to deliver at, or above, the rated power output and is packaged with a Certified Power certificate. The ZX700.5 760 watt five channel amplifier is built with FIT technology for trouble-free use and rejects all of the noise in today's cars.
Part # 267-6950
  • 2 ohm-stable 5 channel amp with two bridgeable stereo amplifiers and a mono subwoofer amplifier built-in
  • 750 watts of real-world power output certified by Kicker
  • FIT (Fail-Safe Integration Technology) rejects noise
  • Includes separate bass boost and variable high-pass and low-pass crossovers for complete system power and control
If your amplifier isn't FIT, what good is it?
Kicker ZX Series amplifiers provide the utmost reliability from the biggest name in trouble-free amplification and loud, clear sound. All Kicker ZX amplifiers feature FIT™ (Fail-Safe Integration Technology) to kill the noise created by the alternator, computer, and audio/video entertainment components found in vehicles today.
FIT's isolated differential inputs reject noise and electrical interference for the quietest operation possible and ultimate audio clarity. Differential inputs also make Kicker amps compatible with any factory or aftermarket radio.
A muting circuit cancels out additional noise that may surge down the line, so listeners enjoy the cleanest, clearest sound possible. Additionally, a choice of three automatic turn-on modes—remote, DC offset, and signal sense—provides ultimate flexibility.
Kicker Certified Power!
Kicker's ZX Series ZX700.5 five channel amplifier is factory tested and certified to provide at least (and in many cases, more than) 85 watts RMS per channel into four channels at 2 ohms and 420 watts RMS into a 2 ohm load on the mono subwoofer channel. Additionally, the AMP1 and AMP2 amplifier sections can be wired for bridged mono operation for two channels for 165 watt RMS power into 4 ohm loads, separate of the SUBWOOFER amplifier channel. Each amplifier includes its own serialized test certificate that documents how much power it can actually put out.
Power Certificate
Example from a Kicker ZX300.1
Tweak your system to your heart's content!
Two built-in, variable crossovers customize your sound system with a switchable, 50 to 200 Hz 12 dB/octave high-pass (one each on AMP1 and AMP2 outputs) and a 50 to 200 Hz 24 dB/octave low-pass (on the SUBWOOFER output), making the ZX700.5 perfect for powering your vehicle's entire sound system.
Looking for budget-friendly line of amplifiers from Kicker? Check out the Kicker DX Series amplifiers!
Use up to 18 dB of boost (centered at 40 Hz) to dial in extra bass to suit your taste, and an outlet for the optional Kicker ZXRC remote bass control puts the power of bass control at your fingertips when driving! Turn on the available -24 dB/octave, fixed, 25 Hz subsonic filter to prevent harmful ultra-low frequency content from damaging your ported subwoofers.
• Kicker certified power output:
AMP1 and AMP2 amplifier sections:
            70 watts x 4 (@ 14.4V, 4Ω, ≤1% THD+N)
            85 watts x 4 (@ 14.4V, 2Ω, ≤1% THD+N)
            165 watts x 2 (@ 14.4V, 4Ω, ≤1% THD+N)
SUBWOOFER amplifier section:
           210 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
           420 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
• Frequency response: 25 to 20,000 Hz (±1 dB)
• Input sensitivity:
            Low level: 125 mV to 5V
            High level: 250 mV to 10V
• Signal-to-noise ratio: >95 dB (A-weighted at rated power output)
• Crossover (switchable):
            AMP1 and AMP2: HI (variable): 50~200 Hz, -12 dB/octave high-pass
            SUBWOOFER (variable): 50~200 Hz, -24 dB/octave low-pass
• Subsonic high-pass filter (fixed): 25 Hz, -24 dB/octave
• Variable bass boost: 0~18 dB @ 40 Hz
• Dimensions (L x W x H): 20" x 9-5/8" x 2-1/8"
Also available in the ZX Series of Kicker amplifiers is the 450 watt ZX450.2 stereo amp, 650 watt ZX650.4 four-channel amp, 760 watt ZX700.5 five-channel amp, 300 watt ZX300.1 mono amp, 400 watt ZX400.1 mono amp, 500 watt ZX500.1 mono amp, and the 750 watt ZX750.1 mono amp. For serious car audio contenders, Kicker makes the 1,000 watt ZXS1000.1 mono amp, 1,500 watt ZXS1500.1 mono amp, and the 2,500 watt ZX2500.1 mono amp.
Kicker's line of ZX Series amplifiers is designed using the same width and height to create a seamless bank of amplifiers when used with the Kicker ZXEC ZX Series amplifier end cap set. For high level (speaker level) speaker signal input, use the optional Kicker ZISL speaker level to line level cable adapter. Each is available for sale in the Related Items section.
Kicker Authorized Badge
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)70 + 210 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels5
  • BrandKicker
  • ModelZX700.5
  • Part Number267-6950
  • UPC713034054832
  • Product CategoryCar Amplifiers
    (1 Reviews)
  • Weight15 lbs.
View similar products to the Kicker ZX700.5 ZX Series 4x85W + 1x420W Bridgeable Multichannel Car Audio Amplifier
in the Car Amplifiers product category.
