Kicker ZX400.1 ZX Series 400W Class D Mono Subwoofer Car Audio Amplifier
Brand:|Model: ZX400.1|Part # 267-6952
Each Kicker ZX Series amplifier is factory tested to deliver at, or above, the rated power output and is packaged with a Certified Power certificate. The ZX400.1 400 watt mono amplifier is built with FIT technology for trouble-free use and to protect against all of the noise in today's cars.
Part # 267-6952
  • 2 ohm-stable mono subwoofer amplifier
  • 400 watts of real-world Class D power output certified by Kicker
  • FIT (Fail-Safe Integration Technology) rejects noise
  • Includes bass boost and a switchable, varible low-pass crossover
If your amplifier isn't FIT, what good is it?
Kicker ZX Series amplifiers provide the utmost reliability from the biggest name in trouble-free amplification and loud, clear sound. All Kicker ZX amplifiers feature FIT™ (Fail-Safe Integration Technology) to kill the noise created by the alternator, computer, and audio/video entertainment components found in vehicles today.
FIT's isolated differential inputs reject noise and electrical interference for the quietest operation possible and ultimate audio clarity. Differential inputs also make Kicker amps compatible with any factory or aftermarket radio. Stereo RCA pass-thru outputs make daisy-chaining amplifiers simple.
A muting circuit cancels out additional noise that may surge down the line, so listeners enjoy the cleanest, clearest sound possible. Additionally, a choice of three automatic turn-on modes—remote, DC offset, and signal sense—provides ultimate flexibility.
Kicker Certified Class D Power!
Kicker's ZX Series Class D ZX400.1 mono subwoofer amplifier is factory tested and certified to provide at least (and in many cases, more than) 400 watts RMS into a 2 ohm load. Each amplifier includes its own serialized test certificate that documents how much power it can actually put out. Not only is this amplifier powerful, the efficient Class D topology keeps the amplifier footprint small.
Power Certificate
Example from a Kicker ZX300.1
Advanced Subwoofer Control!
Use up to 18 dB of boost (centered at 40 Hz) to dial in extra bass to suit your taste, and an outlet for the optional Kicker ZXRC remote bass control puts the power of bass control at your fingertips when driving! Turn on the available -24 dB/octave, fixed, 25 Hz subsonic filter to prevent harmful ultra-low frequency content from damaging your ported subwoofers. The built-in, variable 50 to 200 Hz 24 dB/octave low-pass filter keeps the mids and highs out of your subwoofer's operating range.
• Kicker certified power output:
            200 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
            400 watts x 1 (@ 14.4V, 2Ω, ≤1% THD+N)
• Frequency response: 25 to 200 Hz (±1 dB)
• Input sensitivity:
            Low level: 125 mV to 5V
            High level: 250 mV to 10V
• Signal-to-noise ratio: >95 dB (A-weighted at rated power output)
• Crossover (switchable):
            LO (variable): 50~200 Hz, -24 dB/octave
• Bass boost (variable): 0 to 12 dB @ 40 Hz
• Subsonic high-pass filter (fixed): 25 Hz, -24 dB/octave
• Dimensions (L x W x H): 10-1/4" x 9-5/8" x 2-1/8"
Also available in the ZX Series of Kicker amplifiers is the 450 watt ZX450.2 stereo amp, 650 watt ZX650.4 four-channel amp, 760 watt ZX700.5 five-channel amp, 300 watt ZX300.1 mono amp, 400 watt ZX400.1 mono amp, 500 watt ZX500.1 mono amp, and the 750 watt ZX750.1 mono amp. For serious car audio contenders, Kicker makes the 1,000 watt ZXS1000.1 mono amp, 1,500 watt ZXS1500.1 mono amp, and the 2,500 watt ZX2500.1 mono amp.
Kicker's line of ZX Series amplifiers is designed using the same width and height to create a seamless bank of amplifiers when used with the Kicker ZXEC ZX Series amplifier end cap set. For high level (speaker level) speaker signal input, use the optional Kicker ZISL speaker level to line level cable adapter. Each is available for sale in the Related Items section.
Kicker Authorized Badge
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)200 Watts
  • Special Features2 ohm Stable
  • Output Channels1
  • BrandKicker
  • ModelZX400.1
  • Part Number267-6952
  • UPC713034054757
  • Product CategoryCar Amplifiers
  • Weight7.7 lbs.
View similar products to the Kicker ZX400.1 ZX Series 400W Class D Mono Subwoofer Car Audio Amplifier
in the Car Amplifiers product category.
