Kicker ZX300.1 ZX Series 300W Mono Full Range/Subwoofer Car Audio Amplifier
Brand:|Model: ZX300.1|Part # 267-6951
Each Kicker ZX Series amplifier is factory tested to deliver at, or above, the rated power output and is packaged with a Certified Power certificate. The ZX300.1 300 watt mono amplifier is built with FIT technology for trouble-free use and to protect against all of the noise in today's cars.
Part # 267-6951
  • 2 ohm-stable mono full-range amplifier
  • 300 watts of real-world power output certified by Kicker
  • FIT (Fail-Safe Integration Technology) rejects noise
  • Includes bass boost and a switchable, low-pass crossover
If your amplifier isn't FIT, what good is it?
Kicker ZX Series amplifiers provide the utmost reliability from the biggest name in trouble-free amplification and loud, clear sound. All Kicker ZX amplifiers feature FIT™ (Fail-Safe Integration Technology) to kill the noise created by the alternator, computer, and audio/video entertainment components found in vehicles today.
FIT's isolated differential inputs reject noise and electrical interference for the quietest operation possible and ultimate audio clarity. Differential inputs also make Kicker amps compatible with any factory or aftermarket radio. Stereo RCA pass-thru outputs make daisy-chaining amplifiers simple.
A muting circuit cancels out additional noise that may surge down the line, so listeners enjoy the cleanest, clearest sound possible. Additionally, a choice of three automatic turn-on modes—remote, DC offset, and signal sense—provides ultimate flexibility.
Kicker Certified Power!
Kicker's ZX Series ZX300.1 mono subwoofer amplifier is factory tested and certified to provide at least (and in many cases, more than) 300 watts RMS into a 2 ohm load. Each amplifier includes its own serialized test certificate that documents how much power it can actually put out.
Power Certificate
12 dB of boost (centered at 40 Hz) is switchable to add in extra bass as it suits your taste, and an outlet for the optional Kicker ZXRC remote bass control puts the power of bass control at your fingertips when driving! Turn on the available -24 dB/octave, fixed, 25 Hz subsonic filter to prevent harmful ultra-low frequency content from damaging your ported subwoofers.
The built-in, fixed 80 Hz crossover is switchable for 24 dB/octave of low-pass filtering. You can also bypass the crossover if you prefer to use a car stereo's built-in crossover or to use the ZX300.1 as a full range amplifier.
• Kicker certified power output:
            150 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
            300 watts x 1 (@ 14.4V, 2Ω, ≤1% THD+N)
• Frequency response: 25 to 20,000 Hz (±1 dB)
• Input sensitivity:
            Low level: 125 mV to 5V
            High level: 250 mV to 10V
• Signal-to-noise ratio: >95 dB (A-weighted at rated power output)
• Crossover (switchable):
            LO (fixed): 80 Hz, -12 dB/octave
• Bass boost (fixed): 12 dB @ 40 Hz
• Subsonic high-pass filter (fixed): 25 Hz, -24 dB/octave
• Dimensions (L x W x H): 13-1/2" x 9-5/8" x 2-1/8"
Also available in the ZX Series of Kicker amplifiers is the 450 watt ZX450.2 stereo amp, 650 watt ZX650.4 four-channel amp, 760 watt ZX700.5 five-channel amp, 300 watt ZX300.1 mono amp, 400 watt ZX400.1 mono amp, 500 watt ZX500.1 mono amp, and the 750 watt ZX750.1 mono amp. For serious car audio contenders, Kicker makes the 1,000 watt ZXS1000.1 mono amp, 1,500 watt ZXS1500.1 mono amp, and the 2,500 watt ZX2500.1 mono amp.
Kicker's line of ZX Series amplifiers is designed using the same width and height to create a seamless bank of amplifiers when used with the Kicker ZXEC ZX Series amplifier end cap set. For high level (speaker level) speaker signal input, use the optional Kicker ZISL speaker level to line level cable adapter. Each is available for sale in the Related Items section.
Kicker Authorized Badge
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)150 Watts
  • Special Features2 ohm Stable
  • Output Channels1
  • BrandKicker
  • ModelZX300.1
  • Part Number267-6951
  • UPC713034054719
  • Product CategoryProducts
    (1 Reviews)
  • Weight8.5 lbs.
View similar products to the Kicker ZX300.1 ZX Series 300W Mono Full Range/Subwoofer Car Audio Amplifier
in the Products product category.
