BONUS ITEM INCLUDED
267-6880_ALT_0
267-6880_ALT_1
267-6880_ALT_2
Kicker S8L7 Solo-Baric 8" DVC Subwoofer 2+2 Ohms
Brand:|Model: 11S8L72|Part # 267-6880
Kicker's dual two-ohm voice coil 8" Solo-Baric S8L7 subwoofer offers more bass, than convention subwoofers, in less space.
List Price$299.95
You Save17%
$249.95
Denovo Audio Knock-Down MDF 0.75 cu. ft. Subwoofer Cabinet
Qty: 1Part # 300-7084
List Price:$99.99
*Domestic US orders only
Part # 267-6880
  • Engineered for maximum bass without distortion
  • SoloKon for maximum mechanical coupling to the motor
  • Patented corner ribbed, double-stitched Santoprene surround
  • Works in a wide array of enclosures
Solo-Baric L7 Subwoofer technology continues to maintain the title as the first and foremost authority on bass. It was the world’s first patented square subwoofer, supplying the extra decibels needed for deep, musical bass in a mobile audio system.
The Solo-Baric’s cutting-edge, square-sub design ultimately means more cone area, more air displacement and more decibels than a conventional round woofer. With a patented corner-ribbed, double-stitched Santoprene® surround helping to hold the massive motor structure in place, the Solo-Baric L7 provides durability at high excursion without compromising sound quality.
Kicker's Solo-Baric L7 features a highly-engineered motor structure that handles huge power and provides extreme output. With heavy-duty, ribbon tinsel leads intertwined with semi-progressive spider technology, the square sub promises dependability when pushed to the limit.
L7 Solo-Baric subwoofers revolve around KICKER’s most advanced cone design, the injection-molded SoloKon™, which adds targeted strength for reliable performance and accurate response. The 360°, constant-contact back bracing adheres directly to every contour of the SoloKon square cone.
Venting in SoloKon’s back-bracing and along the perimeter of the spider landing provides maximum air-flow to cool the voice coils during operation. The woofer utilizes a high-mass, extended pole piece to aid in heat dissipation. The 8" Solo-Baric S8L7 subwoofer conducts business in sealed enclosures from 0.33 to 0.75 cubic feet, and ported enclosures from 0.66 to 1.0 cubic feet.
  • Nominal Diameter8"
  • Power Handling (RMS)450 Watts
  • Power Handling (max)900 Watts
  • Impedance2+2 ohms
  • Frequency Response28 to 100 Hz
  • Sensitivity83.6 dB 1W/1m
  • Resonant Frequency (Fs)47.2 Hz
  • DC Resistance (Re)3.3 ohms
  • Mechanical Q (Qms)8.83
  • Electromagnetic Q (Qes)0.80
  • Total Q (Qts)0.73
  • Compliance Equivalent Volume (Vas)0.32 ft.³
  • Maximum Linear Excursion (Xmax)12.2 mm
  • Cone MaterialPoly Composite
  • Surround MaterialSantoprene®
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.1875"
  • Baffle Cutout Diameter7.25"
  • Depth4.75"
  • # Mounting Holes8
  • Sealed Volume1.19 ft.³
  • Sealed F351 Hz
  • Vented Volume1.11 ft.³
  • Vented F328 Hz
  • BrandKicker
  • Model11S8L72
  • Part Number267-6880
  • UPC713034055075
  • Weight14.3000 lbs.
View similar products to the Kicker S8L7 Solo-Baric 8" DVC Subwoofer 2+2 Ohms
