Kicker PKD4 P Series 4 AWG Dual Amplifier Installation Kit
Kicker PKD4 P Series 4 AWG Dual Amplifier 1,500 Watt Installation Kit
Brand:|Model: PKD4|Part # 267-6982
Install your Kicker amplifier with only the best! Use a genuine Kicker P Series amplifier installation kit to get the most out of your Kicker amplifier. The PKD4 amp kit is designed for systems with two amps with up to 1,500 watts of total power.
  • Designed for systems up to 1,500 watts
  • CEA-2015 compliant for true wire gauge
  • 1,862 strand silver-tinned, 100% OFC power and ground cables for main power and ground
  • Connectors, fuse holder, fuse, and 8 AWG cable included
You've spent a lot of time and effort installing your car audio system, selecting only top-notch Kicker components. Don't waste your sweat equity and money finishing your system with cheap, no-name power and ground cables. Install with Kicker amp power kits to extract every last ounce of power out of Kicker amplifiers.
The Kicker P Series PKD4 4 AWG dual amplifier kit is designed for systems with up to 1,500 watts of amplifier power. Kicker's industry standard, CEA-2015 and BC5W2 compliant, 4 gauge power and ground cables are built using 1,862 strands of silver-tinned, 100% oxygen-free copper for maximum power transfer without voltage-drop. Hyper-flex insulation (and section of cable braiding on the positive cable) provides protection from harsh automotive environments, while maintaining ultimate flexibility for a trouble-free installation.
Two genuine Kicker DB1448 power distribution blocks are included to split power. Each distribution block features nickel-plated, all brass hardware for extreme current flow with two 1/0 or 4 AWG cable inputs and four 4 AWG or 8 AWG cable outputs. Kicker's industry standard 8 gauge power and ground cables, built using 735 strands of silver-tinned, 100% oxygen-free copper, are included for connecting amplifiers to the distribution block.
Kit includes:
• 20 ft. of blue 4 AWG power cable
• 5 ft. of blue 8 AWG power cable
• 3 ft. of 4 AWG gray ground cable
• 5 ft. of 8 AWG gray ground cable
• 20 ft. of 18 AWG silver remote turn-on wire
• One AFS Kicker fuseholder with 150A fuse
• Two Kicker DB1448 distribution blocks
• One firewall grommet
• Two 4 AWG spade terminals
• Four 8 AWG spade terminals
• One 18 AWG spade terminals
• Ten cable ties
• One butt splice
Kicker Authorized Badge
  • BrandKicker
  • ModelPKD4
  • Part Number267-6982
  • UPC713034046769
  • Product CategoryCar Amplifier Wiring Kits
  • Weight7 lbs.
View similar products to the Kicker PKD4 P Series 4 AWG Dual Amplifier 1,500 Watt Installation Kit
in the Car Amplifier Wiring Kits product category.
