Kicker DX300.2 DX Series 2x150W Bridgeable Stereo Car Audio Amplifier
Brand:|Model: DX300.2|Part # 267-6961
Each Kicker DX Series amplifier is factory tested to deliver at, or above, the rated power output and is packaged with a Certified Power certificate so you know you're getting your money's worth. The DX300.2 stereo amp provides 300 watts of power.
Part # 267-6961
  • 2 ohm-stable stereo amplifier that is bridgeable into a 4 ohm load
  • 300 watts of real-world power output certified by Kicker
  • FIT (Fail-Safe Integration Technology) rejects noise
  • Includes variable bass boost and a switchable, variable high/low-pass crossover
If your amplifier isn't FIT, what good is it?
Kicker DX Series amplifiers provide the utmost reliability from the biggest name in trouble-free amplification and loud, clear sound. All Kicker DX amplifiers feature FIT™ (Fail-Safe Integration Technology) to kill the noise created by the alternator, computer, and audio/video entertainment components found in vehicles today.
FIT's isolated differential inputs reject noise and electrical interference for the quietest operation possible and ultimate audio clarity. Differential inputs also make Kicker amps compatible with any factory or aftermarket radio. Stereo RCA pass-thru outputs make daisy-chaining amplifiers simple.
A muting circuit cancels out additional noise that may surge down the line, so listeners enjoy the cleanest, clearest sound possible. Additionally, a choice of three automatic turn-on modes—remote, DC offset, and signal sense—provides ultimate flexibility.
Kicker Certified Power!
Kicker's DX Series DX300.2 stereo amplifier is factory tested and certified to provide at least (and in many cases, more than) 150 watts RMS per channel into two channels at 2 ohms or 300 watts RMS bridged mono into a 4 ohm load.  You can also wire the amplifier for 2.1 use to power a stereo set of speakers (2 ohms minimum) and a bridged mono subwoofer (4 ohms minimum) at the same time! Each amplifier includes its own serialized test certificate that documents true power output.
DX125.2 Power Certificate
Example from a Kicker DX125.2
Tweak Your System!
Use up to 18 dB of boost (centered at 40 Hz) to dial in extra bass to suit your tasteTwo switchable crossovers are built into the DX300.2: a 12 dB/octave high-pass filter with variable frequency control from 50 to 200 Hz for front stage and rear fill use, or a 12 dB/octave low-pass filter with variable frequency control from 50 to 200 Hz when using the DX300.2 as a subwoofer amplifier.
• Kicker certified power output:
            75 watts x 2 (@ 14.4V, 4Ω, ≤1% THD+N)
            150 watts x 2 (@ 14.4V, 2Ω, ≤1% THD+N)
            300 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
• Frequency response: 20 to 20,000 Hz (±1 dB)
• Input sensitivity:
            Low level: 125 mV to 5V
            High level: 250 mV to 10V
• Signal-to-noise ratio: >95 dB (A-weighted at rated power output)
• Crossover (switchable):
            LO (variable): 50~200 Hz, -12 dB/octave
            HI (variable): 50~200 Hz, -12 dB/octave
• Bass boost (variable): 0~12 dB @ 40 Hz
• Dimensions (L x W x H): 12-1/4" x 8-5/16" x 2-1/4"
Also available in the DX Series of Kicker amplifiers is the 125 watt DX125.2 stereo amp, 200 watt DX200.4 four-channel amp, 400 watt DX400.4 four-channel amp, 600 watt DX600.5  five-channel amp, 250 watt DX250.1 mono amp, 500 watt DX500.1 mono amp, and the 1,000 watt DX1000.1 mono amp.
For high level (speaker level) speaker signal input, use the optional Kicker ZISL speaker level to line level cable adapter, available for sale in the Related Items section.
Kicker Authorized Badge
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)75 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels2
  • BrandKicker
  • ModelDX300.2
  • Part Number267-6961
  • UPC713034054450
  • Product CategoryCar Amplifiers
    (1 Reviews)
  • Weight6.3 lbs.
View similar products to the Kicker DX300.2 DX Series 2x150W Bridgeable Stereo Car Audio Amplifier
in the Car Amplifiers product category.
