Kicker DX1000.1 DX Series 1000W Class D Mono Car Audio Subwoofer Amplifier
Brand:|Model: DX1000.1|Part # 267-6967
Each Kicker DX Series amplifier is factory tested to deliver at, or above, the rated power output and is packaged with a Certified Power certificate. The DX1000.1 1,000 watt mono sub amplifier is built with FIT technology for trouble-free use and to protect against all of the noise in today's cars.
Part # 267-6967
  • 2 ohm-stable mono subwoofer amplifier
  • 1,000 watts of real-world Class D power output certified by Kicker
  • FIT (Fail-Safe Integration Technology) rejects noise
  • Includes bass boost, subsonic filter, and a switchable, variable low-pass crossover
If your amplifier isn't FIT, what good is it?
Kicker DX Series amplifiers provide the utmost reliability from the biggest name in trouble-free amplification and loud, clear sound. All Kicker DX amplifiers feature FIT™ (Fail-Safe Integration Technology) to kill the noise created by the alternator, computer, and audio/video entertainment components found in vehicles today.
FIT's isolated differential inputs reject noise and electrical interference for the quietest operation possible and ultimate audio clarity. Differential inputs also make Kicker amps compatible with any factory or aftermarket radio. Stereo RCA pass-thru outputs make daisy-chaining amplifiers simple.
A muting circuit cancels out additional noise that may surge down the line, so listeners enjoy the cleanest, clearest sound possible. Additionally, a choice of three automatic turn-on modes—remote, DC offset, and signal sense—provides ultimate flexibility.
Kicker Certified Power!
Kicker's DX Series DX1000.1 mono subwoofer amplifier is factory tested and certified to provide at least (and in many cases, more than) 1,000 watts RMS per channel into a 2 ohm load. Each amplifier includes its own serialized test certificate that documents how much power it can actually put out. Not only is this amplifier powerful, the efficient Class D topology keeps the amplifier footprint small.
DX200.4 Power Certificate
Example from a Kicker DX200.4
Tweak Your System!
Use up to 18 dB of boost (centered at 40 Hz) to dial in extra bass to suit your taste. Turn on the available -18 dB/octave, variable 10 to 30 Hz subsonic filter to prevent harmful ultra-low frequency content from damaging your ported subwoofers. The built-in, variable 50 to 200 Hz, 18 dB/octave low-pass filter keeps the mids and highs out of your subwoofer's operating range.
• Kicker certified power output:
            550 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
            1,000 watts x 1 (@ 14.4V, 2Ω, ≤1% THD+N)
• Frequency response: 20 to 200 Hz (±1 dB)
• Input sensitivity:
            Low level: 125 mV to 5V
            High level: 250 mV to 10V
• Signal-to-noise ratio: >95 dB (A-weighted at rated power output)
• Crossover (switchable):
            LO (variable): 50~200 Hz, -18 dB/octave low-pass
• Variable bass boost : 0~12 dB @ 40 Hz
• Variable subsonic filter: 10~30 Hz, -18 dB/octave
• Dimensions (L x W x H): 10-1/4" x 8-5/16" x 2-1/4"
Also available in the DX Series of Kicker amplifiers is the 125 watt DX125.2 stereo amp, 200 watt DX200.4 four-channel amp, 400 watt DX400.4 four-channel amp, 600 watt DX600.5  five-channel amp, 250 watt DX250.1 mono amp, 500 watt DX500.1 mono amp, and the 1,000 watt DX1000.1 mono amp.
For high level (speaker level) speaker signal input, use the optional Kicker ZISL speaker level to line level cable adapter, available for sale in the Related Items section.
Kicker Authorized Badge
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)550 Watts
  • Special Features2 ohm Stable
  • Output Channels1
  • BrandKicker
  • ModelDX1000.1
  • Part Number267-6967
  • UPC713034054498
  • Product CategoryCar Amplifiers
  • Weight6.85 lbs.
View similar products to the Kicker DX1000.1 DX Series 1000W Class D Mono Car Audio Subwoofer Amplifier
in the Car Amplifiers product category.
